Question about Sony Handycam DCR-TRV11 Mini DV Digital Camcorder
Loose Manual Focusing Lens Device
The manual lens focusing device becomes loose but I can still take video using the auto focus. I am unable to secure it back since the screw heads are from inside the body of the Handycam while the screw threads are on the manual lens focusing device.
  • 320 Answers
There is a bulletin (E31529192) that describes your exact problem and recommends replacing the screws with new different screws to prevent this from happening again. The front section around the lens assembly is only held by 3 screws so access isn't a big deal, just be careful if you try this because there is a cable connected to the microphone that is easy to damage. The new screws are part number 3-056-559-01. Be sure to rate this solution. Thanks!
Posted on Nov 01, 2008
  • Any Guy
    Any Guy Nov 02, 2008
    Wow, not sure why you rated this solution as "thanks for trying". I did everything short of sending you a copy of the bulletin. Was there any reason you felt I deserved this rating?
Pictures didnt develop
Hi Steph Johnson,
Numerous things could be the issue. 1, dirty lens, clean the front and back element, 2. The camera focus is not working properly not focusing on the correct spot. So, are you manual focusing or auto focusing? If it is auto then there could be an issue with that. If your are manual focusing are you sure your diopter setting is correct for your eyes, if not then it may appear correct in the viewfinder, yet be off focus.
Do you have a way to check the lens on a DSLR? If so you can try that lens on the DSLR seeing if there is an error with the lens or if it is your film camera.
Cordially
Oct 20, 2013 | Canon EOS Rebel XS 35mm SLR Camera
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
THE AF AND MF ON THE LENS MEANS WHAT
AF=Auto Focus. With an autofusu capable body, the camera will automatically focus for you using preset focusing zone. Move the Switch to:
MF and it becomes a manual focus lens, where the photographer has to manually focus on his subject.
Nov 18, 2010 | Cameras
My lens stopped working in Auto Focus mode. I can take a picture in manual but I can't seem to focus clearly. I prefer using auto focus for my everyday pictures, but the lens will not work. I am sure it...
there is couple of possibilities like wise when you zoom lens manualy and can you heard the hard noise then could be AF unit itself faulty. AF unit gear is gone.
could be AF shaft broken thats why not focusing
could be AF Flex broken thats why not focusing
for that please bring to canon service center
Aug 11, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Not auto focusing
It could be that the autofocus switch has become unglued from the frame and so it doesn't ever switch on. If your camera doesn't indicate that autofocus is on, but you're not getting an error message, then this might be the problem. Unscrew the two screws that hold the AF switch onto the lens, and see if the underlying PCB upon which the switch is mounted has come loose. If you, take the lens apart from the back and use double-sided tape to re-adhere.
Jun 07, 2008 | Sigma 18-200mm f/3.5-6.3 for Nikon
Samsung digital s73 camera
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Apr 24, 2008 | Samsung Digimax S730 Digital Camera
Open Questions:
Sony Handycam DCR-TRV11 Mini DV Digital Camcorder Logo
138 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
