Question about Epson Office Equipment & Supplies
I have epson DX7450 tells me ink out replaced all but still ink out report have don eall the books operation guide please help regards B D
  • 1 more comment
  • bubbles 5 Nov 01, 2008
    have done the waiting time and a check to see if ink are in all ok
    the last experts advice I have tried still no good
  • bubbles 5 Nov 02, 2008
    all advice taken and done but no luck so will now need to take it into the shop thanks to you all for the help
    bubbles4
    Brigadier General:
  • 6,966 Answers
I believe this issue has been addressed on the FixYa site before. Please follow the instructions of alipally1 as posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 01, 2008
  • Louie  Role
    Louie Role Nov 02, 2008
    Hi again,
    Any development(s)?
    Master:
  • 505 Answers
Make sure there is no dirt in the print cartridge nozzle area and the roller. Make sure there is no paper stuck in. To replace the ink cartrdige properly follow the steps. Also make sure there is no old print jobs pending. You can also uninstall and reinstall the printer
To change the cartridge:
  1. Make sure the printer is turned on and the front paper tray is pulled down, then open the printer cover. (There are illustrated instructions on the inner side of the cover.)
  2. Press the cleaning button (see Figure 6) and hold it for about three seconds until the print head moves left and the power light begins to flash. Warning! Do not move the print head by hand to avoid damaging the printer.
  3. Pull up the ink cartridge clamp until it clasps. The cartridge should rise up from its holder. Warning!Do not remove half-used ink cartridges unless you want to replace it. Once you take a cartridge out, you cannot put it back into the printer even though it is not empty.
  4. Lift the cartridge out of the printer and dispose of it carefully.
  5. Remove the yellow part of the tape seal before placing the new cartridge in place. Warning! Make sure you do not remove the blue portion or try to remove the clear seal underneath the cartridge.
  6. Lower the new ink cartridge into its holder with the label facing up and toward the back of the printer.
  7. Press down the ink cartridge clamp until it locks in place.
  8. If you need to replace the other ink cartridge, repeat steps 3 to 7 before going on to step 9.
  9. Press the cleaning button and close the printer cover. The printer will move the print head and begin charging the ink delivery system. The power button will flash and make various sounds. This will take a couple of minutes and when the charging process is over, the power light will stay on.
  • Indrajit Roy
    Indrajit Roy Nov 01, 2008
  • Indrajit Roy
    If you have tried all the steps I provided and also went through the link I provided then its time we need to get the printer checked by some professional technician. Contact some local tech shop or Bestbuy for the same.
    Thanks
    Genius:
  • 1,550 Answers
Check whether cartridges is placed properly ?
Unplug the unit for 30 minutes and plug back the power chord to the unit .
SOURCE:
How do i change a cartridge for epson printer DX7450
Click on yhe following limk to see the online manual
Click to open the manual. Click on the Printing. Under this title you will see about ink cartridges.
Hope this will work for you.
If it is helpful. give a rating.
luciana44
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX7450/Drivers-Support
Jan 09, 2010 | Epson Office Equipment & Supplies
Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Sep 30, 2009 | Office Equipment & Supplies
Epson DX7450 compatible ink problems
Press and hold the data button
Sep 22, 2009 | Epson Printer
How do i change the language to english on my epson stylus 4050 p
hello
plz tell me the model of the printer?. maybe you need to download the right language software for your printer. go to the www.epson.com site.
Feb 23, 2009 | Epson Office Equipment & Supplies
How to Change the Ink Pads in an Epson DX7450
if you can get to the pipe then i would make your owe ink tank and yes your printer can be reset
Nov 28, 2008 | Office Equipment & Supplies
EPSON PRINTERS how to replace inks in epson DX 7450
You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
Jun 13, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Epson DX7450
use hiest quilty option ok not draft or normal least 1 step above normal printer use more ink better prints ok
Mar 13, 2008 | Computers & Internet
502 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
