Question about Refrigerators
Fridge is cold but always runs.
4 yr old fridge bought new. Past few months elec bill has doubled in price and could not figure out why. The other day I was around the fridge and heard it runing. It stoped. Then approx 10 mins later it was on again. I never opened it. I checked this again tonight and find it will run for say 10 mins off for 6-12 mins then back on again. It's cold so it's fine in that dept. I checked the coils under the unit and they are clean. I cleaned them anyway but this on and off cycling is driving me and my funds crazzy. What could it be ???
Please help.
TIA...
  • Kevin_K_W Nov 01, 2008
    I knew there would be something I forgot to add. I did and they seal great. Last night I was next to it and it was runing. After it shut off, I waited and it came on again in about 5 mins. The thing thats throwing me is that it's cold. I also checked the level of the fridge. It's Perfect.
    Any thing else it could be ?
    TIA...
    Genius:
  • 1,122 Answers
CHECK THE DOOR GASKETS ON THE FREEZER AND FRIG.,IT SOUNDS LIKE THERE IS A AIR LEAK SOMEWHERE,LET ME KNOW-MIKE
Posted on Nov 01, 2008
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
My 3 yr old whirlpool fridge has been constantly running for the last few days. The temps in the fridge and freezer portions are running high and the sides of the fridge are warm to the touch. What they...
" The refrigerator never cycles offThe thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
From repairclinic"
Aug 29, 2008 | Refrigerators
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Refrigerator (Whirlpool) increase in electricity usage
very doubtfull fridge fault would double elec consumption. look at rating plate and see how many watts then equate this to light bulbs. average light bulb is 60-100 watts (uk). does circuit breaker you turned off only control the fridge?
Mar 21, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
