Question about Sharp SF 2020 Copier
THE KEYS ON SHARP AR-5316E X REFUSED TO WORK
THIS IS A NEW MACHINE THAT JUST DID NOT WORK THOUGH IT SHOWED THAT POWER IS IN THE MACHINE. IT ONLY DISPLAYS L AND 1 ALTERNATIVELY. PLEASE HELP WITH POSSIBLE CAUSES AND SOLUTIONS.
AYODELE, EMMANUEL EYITAYO
S.M.A COLLEGE, LAGOS, NIGERIA
smacollege1994@yahoo.co.uk
  • talktobasil Mar 06, 2009
    THIS IS A NEW MACHINE THAT JUST DID NOT WORK THOUGH IT SHOWED THAT POWER IS IN THE MACHINE. IT ONLY Flash the scanner light, DISPLAYS h4, and every key button freezes. PLEASE HELP WITH POSSIBLE CAUSES AND SOLUTIONS.
    Problem Solver:
  • 13 Answers
I dont have the exact manually for this machine although most of the sharp error codes are consistant for most newer models. L1 refers to the scanner area of the machine. The scanner is a part that looks at your original by shinning a light across the page and tranfering that to the machine with mirrors. If you lift the lid and push the print button, you will see it under the glass. Something may be blocking its movement if you hear an unusually noise when trying to print. If no noise it could be a sensor, motor, or a circuit board.
Posted on Nov 01, 2008
  • 25 Answers
The carriage is still locked refere to the user manual to unlock
Posted on Nov 05, 2008
MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-5316E has just refused to power on and its a new machine. Please what do I do?
a new machine under warantee should be returned to the supplier, else check to make sure the cable is well plug to a good socket
Mar 26, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error report
Hello sir; Let's do a reset;
1, press "#","interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if this is helpfull, please give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Is showing me H4 i need the solution now
Dear sir; H-4 Means heat unit problem, try to reset first,follow the steps as below;
1, press "#", " interupt", "clear", "interupt".
2, enter 14.press start.
3, power off and back on again.
If can not be reset then you have go to check the heater lamp, thermos fuse or thermister,
If you need more help let me know I'm alway here. Good luck, don't forget give me a good rating.
HAVE A HAPPY HOLIDAY !!!
Dec 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316E
i want a driver for charp ar-5316e
Oct 28, 2008 | Sharp AR-5316 Advanced Digital Imager...
190 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
