Question about Intel Desktop Board D845BGSE Motherboard
No respons at all !
I just boughted a new chassi, power supply and a new cpu cooler. After i moved m-board, cpu, etc to the new chassi and tryed to start the computer i recived no response at all! The only thing that happened when i turn the power on was a green led on m-board showed. After spending som hours trying to get the machine working I made it work. The problem was between the cpu and the cooling-fan. It was to much "coolingpaste" between the cpu and cooling-fan. So I tooked off some and then the computer worked without any problems!
I think your power supply cables is not able to start your B-board if your power supply is working properly then check mother board jack where you insert your power supply plug in M-board. Then you have to change or repair that jack where you insert power supply wire in M-board. With best regards M. Khalid Shaikh from Pakistan Mobile: +92-332-2631983
Posted on Jul 23, 2007
  • M. Khalid Shaikh
    M. Khalid Shaikh Jul 23, 2007
    Sorry, there are some mistake in answer where i have types B-board please don't think about it, its mean M-board there are just typing mistake please correct that B-board to M-board.
Hi, I removed my PC's motherboard from one case to the new one. after installing every thing when I turned it on, it displayed the message 'CPU fan power failure' I double checked the...
is the new cooler fan does not draw enough power from the terminals that supply the CPU fan. The motherboard is looking for a specific amount of power from the terminal and gives a warning of a failure when the current drawn is different from the specs. You could look at the old cooler to see if the current requirements are marked on it and then match that current with additional fans ETC to the cooler you are wanting to use.
Sep 01, 2011 | Computers & Internet
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
I have 2 problems: 1. can this type acer run mac os? 2. the machine came with duo core processor but i upgraded the machine by removing duo core and put core 2 duo 3.0 processor, now the machine is...
The answer to your first question is yes, your computer is compatible with the MAC OS. However it is very important to continue to ask this question to the MAC Salesperson you deal with when purchasing the software.
The answer to your second question is to do with Heat. Your computer is overheating and is therefore slowing down so it does not fry your CPU. You need to ensure that the Processor Heat sink is making proper contact with the CPU and the fan is connected to the computer main board. Clean the computer of all dust and install as many fans as your computer chassis will allow.
I think this chassis supports up to 80mm fans.
A well cooled computer chassis will work efficiently and effectively.
The Cooler Master Geminii S CPU cooler is a very good CPU cooler for your Processor.
It will reduce the temperature of your Processor by several degrees.
It is very important to get as much, cooler fresh air into your computer chassis as possible. As this will mean that your computer system will run at a far cooler temperature.
damnor01
Feb 08, 2011 | Acer Veriton M265 (PSV880Z001) PC Desktop
Why wont the mouse,keyboard and monitor not work after cpu,pwer supply install...
If the motherboard used to work with the old cpu and power supply, but does not with the new cpu and power supply, then probably the cpu or power supply is bad.
Why did you change the cpu and power supply?
If the power supply went bad, it could have overloaded the mother board as well as the old cpu.
If you think the old cpu went bad, how do you know it was not actually the motherboard that went bad?
All I can suggest is that you double check all the connections.
If you have USB mouse and keyboard, try a DIN connected pair.
If you are using the onboard graphics, try a PCI express card instead.
Tell us if there is any front light activity from the power switch, drive, etc.?
Dec 21, 2010 | Biostar P4M900-M4 Motherboard
How do i remove the motherboard
Before you start read through my published guide as it explains the concept of ESD, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! Open the side panel of your computer chassis, there are usually two screws holding it in place. Now remove the RAM and graphics card. Now remove the cables remembering where they all go. Write it down if you have to. Now you should see screws holding the mainboard in place you need to remove these. You may also need to remove the computer power supply to give yourself more room. Holding the CPU cooler and an edge of the board, gently lift it ever so slightly. Just to take the weight off, then move it a bit towards the front of the chassis. Now ensuring that it, is free lift it steadly and gently. Place it on a non conductive surface. Uninstall the CPU if nessary.
All the best and happy computer rebuild/upgrade!
Thanking you
damnor01
Nov 19, 2010 | E-Machines eMachines Desktop PC
System.hardware.vendor = 'Packard Bell NEC' system.hardware.product = '00000000000000000000000' system.hardware.version = 'PB13109001' system.chassis.manufacturer = 'NEC COMPUTERS...
you need a new CPU cooler and the part you will be needing is called 'CPU COOLER". Go to any computer accessories shop/store within your vicinity and purchase another CPU cooler. You will need to remove the one from your motherboard and use it as a sample to get another one so that you can get exact size of cooler that will fit your CPU because CPU coolers varies in size and shape.
Good luck.
Aug 03, 2010 | Computers & Internet
Motherboard will not start
It seems like there could be a short in the system. Check to make sure that the board is tight in the case, and that no foreign objects are causing the motherboard to short. If there is no obvious problem and the motherboard is new, I would return it as a defect.
May 12, 2009 | Gigabyte Computers & Internet
Problem with installation and no display
Hi alvinkt,
I am using 5450 and it gives me voltage mismatch error and does not boot up, goes straight to BIOS. Is your board revised version with R in the end or pre revision. Could you please help me resolving this error?
Jan 26, 2008 | Intel S5000XVN Motherboard
No pwer to my system until I pull the 12Volt 4 pin power connection to the Motherboard
as you say,the motherboard or the cpu may be the problem, as you need to connect the 4 pin connector as this is the independent 12v power supply for the cpu and not the ZIF socket like older cpu's. You may be getting power to the board when the cpu is not connected, but when it comes to the cpu taking over because the bios has not been checked, nothing else will run, including drives. If you do not get as far as the bios showing on the screen there is a good chance that the cmos chip is damaged on the board normally either from new or because of the board being stressed from flexing when fitting components to the board which is easily done unless the motherboard is supported by something underneath when attaching parts. If the board is already fitted into the chassis of the pc, remove it and double check that it is not shorting on the chassis of your tower.
Jul 02, 2007 | Intel Motherboard
Intel Desktop Board D845BGSE Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
