Question about Singer 1120 Mechanical Sewing Machine
Brothers sewing machine vx 1120
Need to find missing parts to machine , bobbin case, (front load) feed dog, removable free arm. Where to find these items and resonable price
  • mishacatty Nov 16, 2008
    I'm trying to find a new front "box" that makes the front of the machine not a freearm...don't know what it's called! Mine was broken. Thank you! Ann
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at for more information.
Posted on Jan 10, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 46 Answers
SOURCE: thread pickup
I don't know this machine but most machines....You are either using a bent, or incorrect needle. Size matters! If you have the correct needles and they are not damaged in anyway then it may be timing. Unlikely but possible.
one more thing...Are you turning the handwheel in the correct direction?
Posted on Sep 29, 2008
  • 46 Answers
SOURCE: Euro Pro 373om sewing machine
If you have checked the feed dog switch, best to take it to a sewing machine mechanic.
Posted on Oct 24, 2008
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
I don't know where to oil my machine. I haven't a manual.
Singer website has many manuals available as pdfs including yours, oiling is shown in this image after you remove the hook race cover and hook. Most front loading bobbin design machines are like this.
Mar 02, 2015 | Singer 3116 Simple
Problem with brother vx-1120 will not feed fabric
This is usually caused by the feed-dog ( the metal teeth in the area below the needle) being down instead of up - run your finger under there (over the teeth) if they do not stick up above the base line of the machine, they cannot feed the fabric. If this is the case, look in your manual (or and online manual for your machine) and find out how to put the feed dog up. Other than this, some machines have a plastic plate which fits over the feed dog, so that you can do free machine embroidery, if this is the case, you should be able to remove this and the fabric will feed through
Nov 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
My fabric wasn't moving so I lowered the feed dogs and now I cannot raise them. The button in the back of the machine moves both ways but the feed dogs are not moving. They are staying in the down...
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Jul 12, 2011 | Janome 4623 Mechanical Sewing Machine
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Brother VX 1120.... Machine is not making consistent stitches then thread loops and stitch goes straight and half zigzag, thread breaks. Same with straight stitches...will go for about an inch then stitch...
Remove the needle plate, bobbin case and bobbin and clean any lint that has accumulated.
Oil, if the manual indicates you should do this and where it should be done. Some do not as it has to be done by a repair tech.
Re-thread the machine with the presser foot in the up position.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
If the problem continues, the machine will have to be services by a sewing machine repair person. Take samples of the stitching so they can see what it happening - it could be the timing has to be reset.
Feb 16, 2010 | Brother Sewing Machines
Brother VX 1120 sewing machine bobbin holder missing
you can buy one from this website.
Jan 27, 2010 | Sewing Machines
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Jul 06, 2008 | Sewing Machines
Singer 1120 Mechanical Sewing Machine Logo
118 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
