Question about Garden
Murray lawn tractor
I have a 10 year old 12.5 hp murray tractor. It is kept in like newcondition. This is the first problem ever. It has safety sensors in theseat , clutch pedal and blade engage arm. The problem is that after Istart the mower and either try to engage the blade or release theclutch to go - the motor dies. It acts as if you are turning off thekey. I checked the seat sensor with an ohmmeter and it is fine andtried a different battery of known good quality and checked the fuse.All seems okay. I cant seem to figure this one out. Anyone got anyideas I would really appreciate the help. Thanks in advance , Bill
  • 1 more comment
  • finishcar919 Apr 26, 2009
    I have a Murray 405000x8 lawn tractor. The battery was replaced last year.Clutch and seat saftey switches are ok. The motor will not turn over even on a boost from an automatic battery charger. No lights are observed on even with the key turned in both positions. 15 amp fuse fine any suggestions?
  • Anonymous May 05, 2009
    does anyone have a belt diagram for a murray automatic drive wide body with the 17 1/2 hores twin IC
    The belt has come off the pullies and I dont know how to put it back it looks as if the belt is too big and that I need an extra pully. I must be missing something but I dont have a belt diagram so I dont know.
  • Anonymous May 25, 2009
    Same as described with a murray tractor, when i attempt to engaze the blades, the machine shuts down,
  • 14 Answers
One of those safety switches is faulty. They allow the ignition voltage through only when in the proper position, or they send it to ground when in the wrong position. Most have both on one switch. Check continuity on each switch. If there two leads, it will either open or close when switched. If there is 4 leads, one side will open while the other closes. One of these is not opening\closing. Good Luck! Papa
Posted on Nov 15, 2008
    New Friend:
  • 71 Answers
Check your key switch. Sometimes the backside will get dirt and grass in between the terminals-thus creating a contact that shouldn't be. Found 2 of these this summer.
Posted on Sep 06, 2013
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I have a problem with the safety switches on my riding lawn mower
e841a1bd-a315-49bb-ae7c-9ba2aedccbb6.gifCheck this diagram. It is most likely the deck switch. as this is a safety switch i would recommend replacing it instead of bypassing it.
Jan 13, 2014 | Murray Garden
My murray lawn tractor stops running after 10-20 minutes. I replaced the fuel filter and cap, spark plug, oil, gas. I do not have a spark after it cuts off. Any ideas??
First I would bypass all the safety interlocks and see if it still shuts down, if so I would test the ignition switch and if that does not find the problem, the kill wire may be shorting to the block under one of the wire clamps. If all that fails, try replacing the coil.
junkl
Feb 10, 2013 | Murray Garden
When engaging mower blades speed drops or stops
Check throttle cable at carb and make sure you have full travel. Sounds like rpm is little to low. Throttle cables are usually held in place with 1 screw and a washer. Put cable at full throttle loosen screwand pull back until throttle at carb in at full then tighten screw.
Mar 07, 2010 | Garden
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need a belt. 12 hp 40 in. deck lawn tractor. Murray. Model: 40710a Date: 1404 What size do I need? Mower man in town can't seem to figure it out
Hey...my name is Keith...im not sure which belt you are asking for...but the drive belt is a 37X61 and the deck belt is a 37X62..i hope this helps
Jul 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
May 31, 2009 | Garden
Garden Logo
2,680 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
