Question about Linksys Wireless-G WRTP54G Router
Can't Remote Desktop from outside my local network
Router Linksys
Able to use Remote Desktop within my home network.
When attempting from outside my network, it doesn't work
  • 1,269 Answers
You'll just need to forward the port for remote desktop (RDP).
Posted on Nov 01, 2008
Have RV042 set up with Cox Cable and ATT DSL. System works fine as long as all client computers on network have a Static IP. I have DHCP enabled on the Router, when connecting a PC set for DHCP the router...
> everything is good
The connection between each computer and the router is the "good" part.
Thus, the router is routing packets "between" each of the computers (clients & servers) within your local area network.
However, your problem seems to be on the 'WAN' (Wide Area Network) side, namely between the router's WAN port and the DSL-modem, and/or between the DSL-modem and the telephone-jack on the wall, and/or the telephone-wires inside your walls, and/or the telephone-wires from the outside of your building to the nearest telephone company's CO (Central Office).
As a test, disconnect the router from the DSL-modem, and directly connect one computer, to see if the "then it will/not" behaviour still happens when the router is not active, i.e., "bypassed".
Then, contact your ISP, and get them to trouble-shoot while that one computer is connected.
Mar 09, 2011 | Linksys RV042 VPN Router
I'm trying to connect a remote desktop equipped with Linksys network adapter to internet via a home LAN. Though the network shows that it is connected to the home LAN, when i attempt to connect to...
The setup disc for the router only needs to be run once when setting up the router to work with your internet provider and modem/router. You can try putting the disc in your desktop computer and reconfiguring the router.
Feb 28, 2011 | Cisco Linksys WirelessG Broadband Router...
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Feb 12, 2011 | Uniden Wireless Security Surveillance...
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
How to watch IP Camera on internet by using DSL-2640T??
let me give you few suggestions and then you can take it from there.
firstly IP camera is just what its name needs a fixed IP address it may be local as in your lan where it is working or a IP address from ISP.
Now when you connect it behind router... it is essentially a camera connected to LAN.
now the problem is will give access to your router since that is connected to dynamic IP addressing. However Ip camera is behind router and to access it you need to open proper protocol and port in router .consult your router manual for doing that.
with your current setup that is the only solution. however you can connect Ip camera directly to ISP line and then use dyndns as in case of router. though i dont know how feasible that will be for have not mentioned IP camera model so cant help with specific details.
Aug 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Mar 29, 2008 | D-Link DI-704P Router
Linksys Wireless-G WRTP54G Router Logo
207 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
