Question about Toshiba 42H81 42" Rear Projection Television
Red is out of line
Toshiba 42h81;red converge will not adjust in touch focus or manually any suggestions or part #'s?. is it an easy fix or expensive? should i leave it to a pro? it will adjust up or down but not right to left when done manually.
I had the same problem. Repair guy came out (it was under warranty) and replaced it with part # 392-110, an IC. System needs two of them, I think, at about $26 each (www.partstore.com). Good luck! --Mark Wild
Posted on Apr 24, 2007
    Sergeant:
  • 337 Answers
Is time to call a Pro,the repair will need parts replaced and then it might need to be adjusted from the service menu.
Posted on Sep 20, 2006
My picture is wavy and out of focus. when i touch the auto focus it goes through the function but ends with failure. it is a toshiba 42h81.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 14, 2010 | Toshiba 42H81 42" Rear Projection...
When the TV is on, on the outlines of people and text are in Red and Green lines. I have tried the touch focus and it is not working. it is saying that there is a "touch focus error" can I manually adjust...
you need 2 new convergence chips, part number stk 392-110, also check for burnt up resistors next to the chips, major disassembly and soldering, you probably need a tv repairman.
Sep 24, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Red is out of convergence
I would stay away from that repair man. That model has just one Convergence IC number STK393-110 and it takes about 45 minutes from start to finish to remove the old IC and install the new one. You can get the replacement IC at the following link and they provide free instalation instructions with pictures so you can do the repair yourself for less than 30.00. Heres the link. You need just 1 STK393-110 Convergence IC they have free shipping as well.
http://servicemanuals.vstore.ca/
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Red line
Need convergence IC's and probably several resistors that have changed value. Seek professional help, someone who uses ORIGINAL ic's, not generic or knock-offs
Jan 03, 2008 | Toshiba 42H81 42" Rear Projection...
42h81
I am having the same problem with my red lamp. i get an error on the touch focus and I cannot manually converge the red lamp.
let me know if you find out a way to fix the problem
chad
Dec 27, 2007 | Toshiba 42H83 42" Rear Projection...
Still green
go In service convergence mode and try to adjust red and green if you cant then it's convergance amp ic's
if you can adjust them so they align up try doing a touch fous after that,.
Dec 16, 2007 | Toshiba 42H81 42" Rear Projection...
TOSHIBA REAR PROJECTION TV 42H81
you have a convergence problem that will require the replacement of the convergence amp ics.
Nov 29, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 42H81 Red Vertical bar on right side
The symptom suggest a faulty converge ic.you need to replace that ic ( stk392-110 ).
Aug 06, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
