Question about Frigidaire GLWS1339C 3.0 Cu. Ft. Top Loading Washer
5 yr old washer is leaking
Last night my washer began making a grinding noise. This happened when it was pumping water out for the final spin. It then leaked water, at least a gallon. The water appeared to be coming from the bottom of the machine. I thought I could maybe take a look at the pump, but this darn machine looks pretty difficult to get into. I'd appreciate any input on possible problems and/or how to get into this 5 year old Frigidaire top loading washer. Thank you.
  • LINDA SCHNEIDER Sep 19, 2006
    Catriver, I bow to your guru-ness, and thankfully.
    When I was finally able to see the silly little pump, I ran in some water and moved the timer to where it should have begun pumping out (with a screwdriver poked against the latch switch). It went into spin with no pumping going on, so I think the pump is definitely the problem. Golly, that thing's EASY to get into, after you learn the secret!
    Thank you.
  • Anonymous Mar 12, 2014
    washer leaks when running a load of clothes. could water have frozen and cracked the plastic pump or something?
    President:
  • 878 Answers
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Posted on Sep 19, 2006
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Pump or bearing problem?
If this is a top load maytag, the pump bearing sleeve will rub the pump pulley and make a grinding noise. Replace the pump.
Sep 26, 2013 | Maytag Washing Machines
Water has been leaking out of the bottom of my washer, and it has been making a horrible grinding sound. It finally stopped spinning last night, though it makes noises and tries to run.
Hi just read your posting.Now when is the machine noisy?Is it when the machine pumps out the water or when the bowl spins.Sorry to ask you this but please be accurate when you reply to this question.The reason being is that if it is noisy when it pumps the water it could be your pump but if it is noisy when the bowl turns for the spin then the problem will be your bearings and seals.Select a spin cycle and push start,is it noisy as soon as you push the start button?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer won't pump out water makes a grinding noise when turned on
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 13, 2010 | Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
While washing a blanket last night the last spin and rinse cycle failed to happen and the water would not pump out. The motor made a noise I would not say a grinding noise but it was rough. There was an...
The out of balance circuit only gets checked after 90 rpms. So if your balance circuit is open here is what you will notice... In spin cycle the machine will start the ramp up, hit 90 rpm, stop, tumble, attempt to ramp up again and repeat this pattern and not get up to full spin speed.
There should be an electrical diagram in the console area so you can see the inertia switches wiring. On the earlier machines the wires are blue in color.
The first user mentioned that the water is not pumping out? the pump could be clogged and need taken apart and cleaned. A dime can stop the pump.
See www.neptunehelp.com for more Neptune tips.
Feb 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Kenmore 60 series grinds when spin starts
try taking the pump off the motor and see if the grinding noise stops could be something in your pump or a bad pump
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLWS1339C 3.0 Cu. Ft. Top Loading Washer Logo
257 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
