Dell dimension 3000
After startup I receive the Message - Primary drive 1 not found &
- Secondary dive 1 not found.
I was told by self- proclaimed ( I found this out later he's not ) to go into my bios and change a couple of things. Like an IDIOT I did and have had this issue ever since , I have lived with for to long. I just restored all my files and am left with this last problem. Can Anyone help - can I reset my bios to factory settings?
  • 849 Answers
Yeah go for it, restore the factory setting,
Posted on Nov 01, 2008
How do I run a set up program
Generally, one enters the BIOS Setup screen by pressing either F2 or Del. There is usually a message on the bottom of the first boot screen that indicates what button is correct for that model.
Looking further into the details that you have given, it seems that your CMOS battery has died, so you will need to replace that. (This is what is causing the "Time of Day Not Set" message most likely.) You can get the appropriate battery at Radio Shack (if nowhere else) for about $5 or $6.
Oct 17, 2014 | Dell Dimension 3000 PC Desktop
Had a problem with my drive getting on internet installed new hard drive now can not boot up dont see drives
it sounds that you have problem in the mother board, you can hooked up your drive to other pc as slave just to ensure if it will read. if ok, then their is no problem in your hard drive also with other drive.
Nov 19, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
After I turn on my computer I get a message that says; Primary drive 0 not found, primary drive 1 not found, secondary drive 1 not found, strike f1 key to continue, f2 to run the setup utility.
If you have a spare working hard drive to test in this computer, swap it out with the existing one. All you have to do is verify that a drive is found during the post. If you get the same message, I would suspect the IDE controller on the motherboard has failed. With the age of the computer (5 years), I would suggest getting a new or used computer to replace it. You may be able to find a replacement motherboard for it, but then to keep it legal with a Windows operating system, you have to locate a motherboard of the same make/model.
Aug 26, 2010 | Dell Dimension 3000 PC Desktop
Dell dimension 8100 wont start windows at times
It could be a virus, run antivirus scans, or could be your drive cables, Or even an Occaision glitch. Even perfectly running machine have glitches.
Jul 15, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
Before I start my dell dimension 2400 computer up, I have to disconnect my usb mouse and usb keyboard because if I don't I will get these 2 errors, Primary drive 1 not found and Secondary drive 1 not...
The resolution for this is to go into the BIOS with the help of F2. Then look for the option USB Legacy devices. If it is enabled disable it or vice-a-versa. Also look for Boot from USB devices. Please disable that option. And select the first boot device to be the HDD (Internal hard drive)
Jul 11, 2009 | Dell Dimension 2400 PC Desktop
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
I'm getting a message saying ''primary drive 0 not found''
Either the BIOS is not configured to sense the connector where your hard drive is attached or the drive is dead and unreadable.
Start the machine and press F2 when you see the Dell logo. This should get you into the BIOS setup. Come down to Drive Information and see if your HDD is listed under IDE1 (or Primary Master). The BIOS should list the model number and capacity. If IDE1 is off or disabled, change the setting, reboot and go back into BIOS. If you still can not see the HDD in BIOS, remove it and put it as a secondary drive in a different machine to see if it comes up. If not, you have a dead drive.
Dec 30, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
