I'm having problem with my Fanthom USB drive...all of a sudden my Mac G5 is not reading my Fanthom drive...the external drive blue light is on but it doesn't flicker the orange to blue anymore...and so the computer is not reading the drive...the Fanthom icon doesn't appear on the desktop....can you help. Thanks, Jack
  • art2go2006 Nov 01, 2008
    Thanks for you quick reply....how did you remount the drive in another enclosure? Thanks.
  • 33 Answers
I had one of these external drives from the same manufacturer and had the exact same problem.
Based on my own experience I would suspect the enclosure has died.
The drive inside of mine was completely functional.
I simply mounted the drive in another enclosure.
Posted on Nov 01, 2008
  • TF Nov 02, 2008
    Remove the drive from its current enclosure, but be aware this will void the warranty.
    You can test the drive before you buy another enclosure by installing it into your computer per the computer manufacturer's instructions.
    If you install it proprly and you don't need it as an external drive, you can simply leave it installed.
    However, if you need it as an external drive, unistall it from the computer and install it into an external enclosure.
    Here is a link for a place to buy external enclosures. Make sure you get the right kind of enclosure for your hard drive either ATA (IDE) or SATA. Choose one that has a USB2.0 or Firewire connection, if your computer has the available ports.
    http://www.directron.com/externalhd.html
    The Vantec Nexstar 3 line are solid performers and have never given me any trouble.
    As far as the actual physical installation into the enclosure, its a piece of cake. Just read the directions; you should have no problem.
Is it formatted as NTFS? What OS on the PC? What program did you download since it should not be required?
Sounds like the drive is broken or the cable. Does the power light on the drive light up?
Jul 24, 2014 | SimpleTech 320GB SimpleDrive External by...
Undetected in mac
The interface in the case would seem to have failed. They are usually not the same standard as those used in a computer.
May 01, 2013 | Toshiba Computers & Internet
I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
ry connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Hdd seagate 2tb suddenly not work i connect and the light flash and my pc and mac dont read the hdd pplease help
Hello OS,
The GoFlex Desk external drive have ample storage capacity and it's easy to upgrade to any interface you need.Pairing the desktop hard drive with a GoFlex USB 3.0 or FireWire800/USB 2.0 adapter to increase your performance by up to 10 times. Works interchangeably between a PC or a Mac® computer.
Please visit the link provided below :
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=214431&NewLang=en
Jun 07, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
My Toshiba external hard disk does not accepting backup from mac G5
my external HDD is not letting me drag and drop files from my mac. Is this my mac being secure? If so how can i remove it so i can store audio files on this device. thanks
Jan 23, 2011 | Toshiba 120GB USB 2.0 Portable External...
I have a 500g external simple drive. i am getting a message that i can only read on my mac.
Copy all the data onto your Mac computer.
Take the external drive to a PC computer, and "reformat" it, using "quick format".
Take the external drive back your Mac computer,
and write all the "saved" files onto the drive.
Nov 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
External sound problems on Power Mac G5
Mac g5 sound output is echoing? what is the reason
Dec 02, 2008 | Apple Power Mac G5 Desktop
Fantom 1TB external USB drive failure, only half seen by MAC
the operating system may be corrupting format the hard disk drive the notice its behaviour
May 21, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
