Deleted os I acedentally deleted my laptop windows xp os.
  • 849 Answers
Re-install it by using recovery cd
Posted on Nov 01, 2008
I have 2 copies of OS and want to remove bad one
type in msconfig and depending on what os you have type this in program search or run box if windows xp. in the box that comes up select boot. there you will have the option to delete the bad os when you highlite it. it will ask you to restart your computer and bad os should be deleted.make sure you delete the bad os and not the good 1. hope this helps.
Aug 08, 2012 | Dell Inspiron 5100 Laptop
Your computer was unable to star
Hi Dear,
Your system windows (Operating System) was corrupt, so you have two option in your hand first you should format your PC and install the new window (Operating System) & second you repair you old windows(OS) if you have windows CD then try this link to repair & format PC. if you chose first option then you all data will delete, & repair window your data will not delete.
Option :
1.For Repairing you OS (windows XP)
2.For New OS Installation (Windows XP)
If you are using difference OS version let me know.
Thanks
May 21, 2012 | Acer Computers & Internet
I have a laptop pc ( compaq presario cq60) vista O.S base model.now i want to install windows xp on that. when i installing windows xp a blue screen come and stop my process. please give an solution for...
Hello
In the setup process for xp,you need to delete and format any partition on drive c.
This will completly erase any vista os files and allow xp to install.
Mar 31, 2011 | Computers & Internet
There is only one OS, but during booting it shows three
Delete the OS Command line inside the MSConfig indow by clicking start - run -type msconfig then press enter. On the MS config window click on the boot.ini tab then you will see the command line inside the text box. Leave the first command line from [Boot Loader] till the end of the command line of your Default Operating system.
Example:
(Leave this lines)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
(Till here!)
(Delete this line)
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Viz XP Example line Professional" /fastdetect (up to here)
any other command line that says Viz XP -- you may delete it. Click apply button then Restart the computer afterwards and this should fix the issue.
Should you have any other questions just please leave a comment.
Cheers~
Jun 28, 2010 | Intel D845GVSR Motherboard
How to completely clean /delete/and thn reboot
What do you mean clean, delete and reboot? Are you trying to re-format the whole hard drive? If yes then follow this. 1. Prepare the Windows OS disc. 2. Use ac adapter on laptop. 3. Power on laptop then immediately keep tapping on F12. 4. Boot menu will appear use then the arrow keys highlight on onboard CD/DVD-ROM then insert the windows OS disc then press the enter key. Just wait until it loaded the windows setup. Just follow the prompt on the screen on deleting the partition. Windows has its instructions during the process.
Mar 31, 2010 | Dell INSPIRON 6000 CENTRINO...
How to delete windows from a laptop
You can't delete your system unless you are installing a new OS. If you are trying to do that, you need a disk with OS installation on it, insert it, restart your computer, go into BIOS and under BOOT SETTINGS choose your cd-dvd rom for the first boot device. Press F10, and then YES
After rebooting, your computer will start a boot from the ****. Afterwords, just follow the instructions, and that's it.
Nov 17, 2009 | Computers & Internet
I formatted my laptop which is using windows vista,how will i bring back the vista again?
once you format your sytems means, you deleted whole OS so you need to reinstall fresh OS on it.
you supposed to have a recovery disk (it comes alongwith laptop while buying it)
but it depends on what basic OS was there when you bought your Laptop if there was XP then you got XP OS recovery disk if there was vista then you have Vista recovery disk.
if you don't have recovery disk then you need to get new Vista disk from market to install back vista in your laptop.
thank you,
Jan 02, 2009 | Computers & Internet
Canon pixma500
This product can be used with Windows Vista.
  • To use it with Windows Vista, you must install the driver software for Windows Vista.
  • The Windows XP drivers for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP driver software first; then, upgrade the OS to Windows Vista and install Vista driver software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall the Windows XP drivers before installing Vista drivers.
I hope it helps!!!
Nov 22, 2008 | Canon Pixma MP500 All-In-One InkJet...
Acer aspire 3680 PQSERVICE
if you have installed vista and change it to xp, you should first delete or reformat your current OS (Operating System) which I believe is the ur vista.
formatting OS:
-insert your xp disk then press F8
-click format or delete files ( i don't know the exact message that will appear on the screen)
-then install windows XP (just follow the instruction that you will see on the screen)
hope this would help you solve your problem..
thanks.. :)
Aug 22, 2008 | Acer Aspire 5610-4648 Notebook
Dell inspiron 7500 pentium 3, 18 gigs
Hopefully your other OS's are on a different drive letter (d: or e: for example). As long as they are then there is no conflict with XP.
You could effectively remove access to them by editing c:\BOOT.INI . Note that you will have to right click boot.ini, select "properties" and remove the "read only" and "hidden" properties for the file before editing it. I would recommend making a copy of the boot.ini first for a backup.
Then just open it with notepad. There will be one line for each OS in there. just delete the extra lines. Then you can just erase or format the partitions for the other OS's.
Dec 13, 2007 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
