Question about Pentax IQZoom 160 Date 35mm Point and Shoot Camera
Winding mech stuck??
When I install battery ,camera rewinds automatically??Any ideas what's going on? Thanks
    Champion:
  • 216 Answers
Check to see if the rubbery rewind button on the camera bottom is cock-eyed or damaged.
Posted on Nov 01, 2006
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
Camera wont let me rewind film
Get a heavy coat and zip it shut, take it and the camera into the darkest room in your home, put the camera in the coat and reach through the sleeves backwards, Grab the camera and open it and take out the film, wind it back into the cannisteer by hand.
Dec 13, 2014 | Photography
The battery in my Minolta Maxxum 7000 died while rewinding. I replaced the battery, but nothing happens and the rewind-button/slide is stuck. How do I reset this slide, so I can rewind my film?
Sorry to hear you're having troubles with your Minolta. First thing I would do is make sure that the batteries you put in our good and that you do have power coming out of that battery box. He didn't mention whether the batteries had corroded or if there had been any corrosion previously. The rewind button on this camera will not reset until the camera again advances. In other words it is an automatic release on the camera fires the first time after a rewind. So as an beginning answer to your question I would check the batteries again make sure that all contacts are absolutely clean and as you may have noticed the battery boxes on the Minolta do pivot. The contacts under the pivot points also have to be clean. If you checked all of these issues and you're still having problems please feel free to e-mail me at, Dave@advancedcamera.com.
Thank you good luck
Aug 10, 2011 | Minolta Maxxum 7000 35mm SLR Camera
How do I unload or rewind the film
Not All camera do it the same way.
Some have an electric rewind - usually those that automatically advance the film after each picture. They will have a catch somewhere that lets you open the back - it's normally at the right hand side (as you look at the back) or.. Cameras that you advance the film with a lever under your right thumb usually have a rewind crank at the left hand end of the camera . Generally it is on the top folded into the round thing but sometimes it is on the bottom in a matching place. You unfold the crank so that you can wind the film back into its can. However, You must first operate a little button that will be located in a small recess on the base of the camera - this disengages the wind-on machanism inside the camera so that the film can go the other way. Normally you have to keep this pressed all the time you are winding.
When the film is all in the can you will feel the wind ease off and the noise will change . now you can open the camera. Again this is done in different ways on different cameras, but the commonest is to take the winding crank and pull it upwards as if you are trying to pull it out of the top of the camera. It will come so far than suddenly the back will release and open a short way.
Some cameras have a slider hidden at the right hand end on the side, that looks like a small silver bar that you pull down with your thumb-nail.
Jun 26, 2011 | Canon Photography
The film advance lever is stuck on my Minolta Hi-Matic C. I bought this at a thrift store today to see if it worked. The film advance lever worked fine for a while and then got stuck. Put a new battery...
Have you rewound the film? If you rewind the file completely and pull out the rewind know, it will pop the back open . . . and can remove the film cassette. While the back is still open, complete the cycle on the winding crank. The winding crank should return to "Normal" arter you complete the winding cycle. When you close the back, everything should go back to normal.
Jul 18, 2017 | Minolta Photography
Jammed canon at1 slr
Believe it or not, i just put a new battery in it and BINGO, back to life again....cheers G.
Jul 22, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
Feb 21, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Dec 15, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Nikon N50 SLR film
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
May 29, 2007 | Nikon N50 35mm SLR Camera
Pentax IQZoom 160 Date 35mm Point and Shoot Camera Logo
91 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
