Question about Texas Instruments TI-83 Plus Calculator
Dead calculator~! mine too!i havent use it for many mths and now it is DEAD. ): puttin in fresh batteries dont work either.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Posted on Mar 09, 2010
Why don't keys lock and unlock doors anymore?
car came with two RKE fobs (the buttons dead or the metal key part dead)
are you saying both fobs fail?
and are the batteries in them fresh,,, they dont last about this long.
and all else on car works, car drives at night perfectly
why must I ask that?>
if both FOBs fail with fresh batteries?
then the car needs to be scanned and fuses in it checked first.
the fob has a battery
the operators guide tells you what to do.
page 25 it tell you,
http://www.jeep.com/en/owners/manuals/
lost the guide, well there it is
posted over 300 times here.
how to replace the coin cell in the FOB.
do both,
answering for electronic fob buttons DEAD.
not metal key failures.
Feb 10, 2016 | 2008 Jeep Patriot
Dead Battery?
Take out the batteries. Also take out the backup battery. It is a button battery beneath the screw in the battery compartment. Check the button battery volts with a multi-meter. After 5 minutes put the button battery back in and then the fresh batteries. It might work now. Alternatively take out a battery, then hold the clear button and put the battery back in. Then try to turn on. If it still does not work take out a battery press the del button and put the battery back in.
Feb 06, 2014 | Texas Instruments TI-83 Plus Calculator
Batteries are dead will not recharge
I do believe the company sells their own batteries for your product and even if they dont, you can always buy them yourself.First look on the back of your product and see what size you will need.
Nov 26, 2013 | Electrolux Zb2803 Unirapido Rechargeable...
Ti 84 plus cannot clear or divide HELPPP!
We had one that did the same thing. The retailer we purchased it from advised us to remove the batteries and put fresh ones in, then turn it back on. Ours resolved itself. Hope this works for you. If not, return it to the retailer you bought it from. Could be a lemon.
Jul 11, 2012 | Texas Instruments TI-84 PLUS Graphic...
Problem is the top drawer of dishwasher will not come on. The lower drawer seems to be working fine. Any suggestions?
if its no lights or fault codes its the main filter circut board can buy this for $50-140 depend on your supplier this happens when crewles gets into it if you remove bottome drae have look see if you se any dead crawles that what happend & secondly could be your controll board blown up from crawles this havent been buitl well for australian hot climents but built well over seas got cold wether and wont get this problem and when buying this draw dishwashers they dont tell you to put baits under the bottom draw and bug spray every where before installing it and keep it up for every 6 mths cheers
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
MY CALCULATOR IS NOT WORKING ANYMORE BUT IF I PUT IT THROUGH TH LIGHT IT WORKS,,BUT I CANT DO IT ANYMORE,PLS HELP OR MAYBE ILL GO BUY NEW ONE..LOL
Hi:
if puttin it to the light makes it work than what you got is some dead batteries you need to replace . Check the back cover and see what batteries your calculator need to be replace it with; than go to the watch repair dept in walmart or meijers buy two batteries and have them take off the back cover and remove the old batteries and replace them with new put your back cover on and your calculator will work as good as new.
Oct 07, 2009 | Office Equipment & Supplies
Battery going dead
The battery regulator may not be functioning properly. At times it will send a charge to the battery and at times it won't. This is normal, but if it is not allowing the battery to receive current when it should then there is a problem. Another possibility is a loose connection in the wiring. I would check the connections first.
Aug 12, 2009 | 2005 Honda VTX 1300 C
Blank lines across the screen of a TI-86 graphing calculator
Try this, hook up new battery and go to MODE and darken and lighten the screen.. do it ten to fifteen times. if that doesn't help, try hook up most left and most right's battery terminal to a DC supply at 4.5V. dont go above 4.5 it will fry your calc (it is design to handle 3V). now you are forcing extra juice into the dead LCD screen lines... and reapeat the MODE + darken trick. I fixed mine like that! Works! and remeber to leave it completely black(darkest) for a while to keep that dead line alive!
Jul 06, 2009 | Texas Instruments TI-86 Calculator
First time used in months
Check the batteries polarity.
Perhaps it needs a "reset", some calcs do have a "button" therefor, some do if you press the start button for some seconds.
Try to leave the calc overnight without any batt. inside.
Sep 19, 2008 | Texas Instruments TI-83 Plus Calculator
Camera switches itself off seconds after turning it on
This is a service center job and I think the lens assy motor is jammed. Take to a near by camera repair center
Feb 04, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Texas Instruments TI-83 Plus Calculator Logo
121 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
