Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry.
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset. If this doesn't work then it's an issue
with the wash pump not pumping the water past the heater efficiently or due to
lack of water to heat. Please make sure that heater is not open circuited and
is heating the water efficiently. You'll have to check the heater using a
multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on
Rx1 ohm setting). If heater is fine then make sure water pressure is optimum
and fill valve is working fine. Hope this helps... Please post back if you
need more information.
Daniel
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
