Question about HTC G1
How can i get my gps to work
Hi
How can I get my gps to work?
I have enable, but where is the icon for gps?
can you help me
please.
Thank you
Juan
padillajuap0@gmail.com
I had gps befor but now it's not there no more how do I put it back on my phone? On my g1
Posted on Jul 14, 2011
  • 2,794 Answers
It's in the maps program under settings. Once it's activated you will get a warning message about the battery life going down when in use but it should deactivate once you are off of Google maps. You will see a satellite dish icon on the upper part of the screen once it is on.
It's works better in mapping mode than satellite mode as well. Due to the amount of time it takes to redraw the screen.
Posted on Nov 07, 2008
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
Jun 18, 2014 | Gateway M6307 Notebook
My Jabra bluetooth headset GNM-OTE3 is fully charged and it is able to connect but it doesn't have sound when I make a call. I couldn't hear the other person's voice at all. I don't know what happened. Can...
Ok I wil try to help you here...
I dont know which model you have but thinking maybe a 200 thru 700 series
Press the Volume Icon.... next screen is there a Checkmark in Mute? if so uncheck it
stay on that screen you will see at the bottom FM Trans... press it
uncheck Enable FM Tranmitter.......... hope that works for you
Oct 22, 2010 | GPS
My gps icon keeps blinking on g1
In home screen, press menu, and press settings. Press Security & location. Uncheck "Use wireless networks," and check "Enable GPS satellites." GPS should now work.
Sep 18, 2009 | HTC G1
Hi, i cannot enable the speed cameras on TOM TOM ONE XL
You need a traffic receiver, avalable from the dealer. it plugs into the charging port
Apr 02, 2009 | Tomtom ONE XL GPS
Cannot enable my gps on the htc touch
Does your phone service support gps? It may not be enabled in your plan. Other than that man im empty. I hope that helps you though
Mar 29, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
WLAN disabled
Hi there.
Try this >>>> right click on the wireless icon in the corner of the screen, from the sub menu select enable.
If that is not there look at the keyboard, hold down the FN key and press F2, a blue light should appear when activated.
Please post back with the results.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | HP Pavilion dv6426us Notebook
G1 gps not working
have you actually enabled the G1's GPS receiver within the phone ?
the GPS is not switched on out of the box aswell as Wifi and Bluetooth.
Try going into the settings and enabling the GPS Satellite receiver and then use the maps application to see if the Satellites can Triangulate your position and find where your at !
hope this helps :D
Greenie UK
Oct 26, 2008 | HTC G1
T Mobile G1 GPS Problems
G1 Gps Problem Fix - I recently had the same issues with the gps giving me the location of cell towers instead of actual location. After looking around the forums, i found the fix and it worked.
Clear you maps cache by going into your application data.
Settings : Applications : Manage Applications : Maps : then push "clear data"
Make sure both your wireless and gps are turned ON
Turn off Phone
Take it outside somewhere that is clear of obstructions (like a large parking lot, or field)
Turn on phone
Once on, press maps
Let it sit in one spot for about 5-10 min, then press my location.
It should find you in just a few seconds. Mine took about 30 seconds.
This should fix most problems you are having.
Presario v6000 microphone
go to control panel and enable your audio driver... reboot your laptop.... now open the audio driver icon from the system tray and try to test the microphone... enable the settings for microphone in it
Sep 18, 2008 | Compaq Presario Notebook
GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Jul 14, 2008 | Apple iPhone 3G
HTC G1 Logo
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
