Question about Kenwood 1090VR Receiver
Kenwood 1090VR only works with Source Direct on.
I have a Kenwood 1090VR receiver. I can only get sound out of it with the source direct turned on. It was intermittently cutting the sound off on zone A. I resoldered the connections to the Voltage regulators and voltages seem fine. Maybe bad solder connections to the DSP chip?
Please help.
  • domwilson Nov 02, 2008
    Found the problem. Two tabs on the front panel connector (front panel to motherboard) were bent and touching. Straigtened and works great.
2 Suggested Answers
  • 13 Answers
SOURCE: Kenwood 1090VR loses sound after a few minutes
First thing to do is to check if this KENWOOD have an input at the back then you try another player i mean dvd player or anything that you can drive or cassette then hear if the same happened again there is something overheating and i pinpiont directly the Power IC is leaking.subject to change.See the number of the IC then buy the same number and change.
Posted on Jan 05, 2008
  • 4234 Answers
SOURCE: Kenwood:1090VR Cracking sound from front speakers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Posted on Feb 06, 2009
Kenwood 1090vr AV surround receiver schematics
Disconnect speakers, turn the system on, if its ok check speakers, impedance could be too low
Mar 29, 2014 | Kenwood Audio Players & Recorders
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
I have a MARANTZ SR7000 Receiver . I would like to play music CDs in direct source mode and also be able to use the subwoofer. How does one do that.
Not sure that this will be possible, direct source will cut out any changes made by the amp, and as a cd is 2 channel stereo, it wont include the subwoofer. Try some of the other settings with direct source mode.
May 03, 2011 | Marantz SR-7000 Receiver
It says "Source Direct" and
I think that your receiver might be set to the wrong input. Try to change the input to "tuner" and you should be able to hear the FM radio. To change the input, all you need to do is press the button labled either source or input
Jan 07, 2011 | Kenwood Audio Players & Recorders
How do i hook up my tv sound to play through my stereo speakers
The following are the best I can do without specifics re: your TV and other TV-related equipment.
Since a TV without an antenna is rarely the source of any programming it is best to feed the receiver the best sound available from the device where it originates - cable / sat / DVD / BluRay / games. Your receiver probably has plenty of inputs to accomodate al of these. I also run the video directly to my TV, which has several video inputs, from each source because IT deserves the best unadulterated video.
If you have a cable box and want the best sound, get it directly and digitally from the cable box and run it to the receiver. Then leave the TV's speakers off for critical viewing with good sound.
Aug 14, 2010 | Kenwood VR-6050 Receiver
I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
Mar 13, 2009 | Aiwa AV-D58 Receiver
Keep us posted.
Dan
Feb 06, 2009 | Kenwood 1090VR Receiver
Jan 05, 2008 | Kenwood 1090VR Receiver
Direct source
I downloaded the manual from some site 5 min. after I posted and it was simple. Turn the reciever off, then press and hold the enter button while you turn it back on. It worked, no problem...
Dec 03, 2007 | Aiwa AV-D58 Receiver
60 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
