Question about OKI C3400n Laser Printer
HOW TO RESET BLACK DRUM AND COUNTER
OKI C3400 LASER PRINTER
  • jgmedina Dec 30, 2008
    Same problem and in additon tried new OKI drum that prints all black. Tried after market chip and printer says it is not connected to network. Lots of dahs! I have two c3400n printers, one will accept the after market chip and the other will not? Any clues?
Conseguí el programa de matenimiento , y coloco la impresora en modo de fabrica para envío, y la impresora continúa imprimiendo
Posted on Dec 19, 2010
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Can i reset the drum life on an oki c3400?
On Oki C3200, there are only 2 terminals on the RH end of the drum -- those are the two you need.
I had trouble getting the wire tucked under the terminals on the drum. What I did that worked was just hook the wires to the spring contacts on the printer frame. Put a piece of black tape over the metal frame just to make sure no short between the frame and the wire. I also found a piece of black tape to retain and keep some tension on the wires worked well.
Analog VOM worked just as advertised -- thanks so much for a quick, easy, no-cost drum reset solution.
Photo attached.
Apr 14, 2011 | OKI C3400n Laser Printer
I have and OKI C3400. My printer is showing globs
yuo have a leaky black toner cartridge
take out the cartridge and look for damage
aslo check the fuser for damge or leaks
replace any damaged cartridge
Mar 22, 2010 | OKI C3400n Laser Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
I have an Oki C3400 that wont print
Could very well be the sensor window. I suggest looking at the side of the drum on the right side and pushing a q tip into the opening. heres an older model thats sort of similar instructions. http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
Also you can check the exact error code here. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Dec 10, 2008 | OKI C3400n Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
OKI C3400n Laser Printer Logo
2,056 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
