Question about Linksys Computers & Internet
Wireless local only
We have had a linksys router since may was working fine till 3 days ago ,now one laptop will only work with cable hooked to it. linksys tech support tried for 3 hrs and as close as we could get was wireless conection but local only not local and internet.help please.
  • wayne upchurch Nov 01, 2008
    it wasn't wifi it was wlan but it works now thanks
  • usdojpr Dec 19, 2008
    i have the same problem. It goes away if I unsecure it by not using the wep. all other computers dont have this problem
    Genius:
  • 1,269 Answers
You should try to uninstall and reinstall the driver for your wi-fi adapter on your laptop. Also, you can try to connect to a different wireless network like a hot spot or coffee shop for you to determine if the router is faulty or the built-in wi-fi adapter of your laptop.
Posted on Nov 01, 2008
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
My WRT54G linksys was connected 3 days ago to the laptop and the ps3. two days ago, i couldnt connect to the internet on the ps3, but could on the laptop. Yesterday, i couldn't connect on either one. I've...
First steps (forgive me if you are already doing this). Hook up the laptop with cat5 network cable to port on router to verify you have internet connectvity. Verify router settings that DHCP is on or off. It should be on unless u are using static IP's on network. Go back wireless and see if you can connect. IF yo do, open a DOS prompt and use ping command (c:>ping 192.168.x.x ) where x.x are the ip setting of router. In most cases the router IP will be set to 192.168.1.1 Check the most basic settings. Sometimes it is a simple thing that is throwing everything off. Also consider if your laptop is at the very edge of your signal area. Try moving laptop right next to router.
Hope this helps.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Wireless router
The problem is the Linksys wireless router is not properly configured. Try downloading the automatic configuration file which can be accessed from the Linksys site for your specific model wireless router.
Hope this helps you.
Dec 21, 2008 | Linksys Wireless-G WRT54GS Router...
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
Connection drop-outs
Is your laptop wireless adapter a compatable brand. It doesn't necessarily mean the router is bad, you may even be getting RADIO interference from a cordlees or a cell phone in it's path. Do you have the capability to plug a cat-5 cable directly into your laptop from the router when you lose wireless? Check the wireless channels and see about changing the channel on your cordless phone too. May not work, just a hunch.
Good Luck
Mar 18, 2008 | Linksys Wireless-G WRT54G Router
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
147 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
