Question about Philips Magnavox 27MS343S 27" TV
Dvd input there is no button for tv/dvd on my magnavox tv, so i am not sure how to input the signal from the dvd player to the tv...HELP
    Genius:
  • Philips Master
  • 1,635 Answers
I don't know this model of TV in particular. I can give you a generic answer that should allow you to figure this out.
Check the options for your TV set. See if there are the connectors at the rear side for an external audio and video input that is compatible to your DVD player. This would be an external video audio input option. If there is and you do not have a switch for it, then you need the original factory remote contol. Many of the universal remotes lack the full features of the products.
If your TV set does not have the option for external video and audio, one work around is to purchase an audio video RF TV modulator. Many of the stores that sell TV options usually carry these devices. You can then add a CATV 2 way cable switch to switch between the modulator and your cable service or antenna. You will have to purchase the additional necessary interconnect cables.
On the input of the RF TV modulator you would connect the DVD player. The quality will not be very good, but at least you will be able to watch the DVD player on your TV set.
Once you figure everything out, bring a print of this email to the dealer. When he looks at all this he should know exactly what you require.
Jerry G.
Posted on Nov 01, 2008
I deleted channel 3. and have had it unplug for a week have new remote but still cant get 3 back help ....tv deprived ty ty
if your using the cable input to tv. just use the auto program button to find that input have a dvd or vcr playing to give it a signal to find. usually the default channel will be 3 or 4
Jul 25, 2015 | Televison & Video
I need to know how to hook up a d DVD/VCR to it.
Ur tv have a RCA INPUT holes like Y,R,W INPUT holes from the Front or the Back of the tv wright?Yes.U must buy or have it already a RCA components cable Y,R,W wires.Connected the RCA components cable Y,R,W wires to the DVD player Y,R,W OUTPUT holes and the other end of the RCA components cable wires Y,R,W connected to the tv Y,R,W INPUT holes.Now the tv and DVD player is on ok.Now u playing the DVD player contents Disc and push the INPUT modes on the tv like VIDEO 1 or 2 by the tv remote or manual button on the tv.Now u should have video picture of the DVD Disc contents playing.
Aug 15, 2011 | Philips Magnavox MT2501C 25" TV
I just finished watching a video and the screen now says "no signal" how do I return this to watch TV?
switch inputs. if you were watching a dvd and turned off the dvd player the tv will no longer be recieving a signal. turn the dvd player back on to test.
Mar 05, 2011 | Philips Magnavox 27MS343S 27" TV
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
Tv magnovox tv
firstly try that tv to a different tv
if this works
then check your tv av connections in side tv
also check cables continuity
if this fails buy a AV/ RF converter, have your AV be connected to a converter, and let your output be RF feed to a tv, RF input, so instead of using AV on your tv you will be using RFchannel mode
Mar 16, 2009 | Philips Magnavox 27MS343S 27" TV
Dvd hookup to phillips tv without inputs
Have yourself a VCR that has a Scart input, or Video in, and feed the DVD in there. Connect your TV to the VCR, and tune it in to the video channel, using aerial lead and tuner.
When you flick VCR to AV1 (or similar) you should see the DVD appear on the TV Video Channel :)
Mar 14, 2009 | Philips Magnavox 27MS343S 27" TV
TV connecting to portable dvd player
You should be able to hook into your tv with no problem using a audio/video jack available at any radio shack, you would tune your tv to either the select "video" channel or ch.3, your t.v. set should have no problem with the attached device.
Sep 07, 2008 | Philips 26PW6341 26" TV
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Philips Magnavox 27MS343S 27" TV Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
