Hard disk failure... unable to start
I hav seagate barracuda 7200 160GB sata hdd .. i am unable to start my hard disk i.e. not able to start my comp with it ... even tried making it as a slave drive.. i think the power pins of the hdd has shorted and i hav important data in drive tat i want to recover....
is there any solution to this problem...
help reqd. urgent... plzzz I pluged my desk top into the external harddrive and now the harddrive dont work. (there is a voltage differance,) so i would like to find a new or 2nd hand board, Se No 100406534 F 7729EVAF. Can you help. The harddrive is a Seagate Barracuda 7200-10 St 3400620A.
    Novelist:
  • 208 Answers
FIRST PART OF PROBLEM, YES THE DATA MIGHT BE ABLE TO BE RECOVERED, BUT IT WILL TAKE SPECIAL SOFTWARE TO DO IT. YOU NEED TO FIND A REPAIR OUTLET THAT CAN RECOVER DATA ON A DAMAGED DRIVE. THEY CAN HANDLE THINGS LIKE THIS.
THE SECOND PART IS HARD TO READ BUT I WOULD SAY IF YOU ARE MIXING VOLTAGES ETC. YOU PROBABLY HAVE FRIED NUMEROUS THINGS. THIS IS NOT GOOD. FINDING A SECOND HAND BOARD IS VERY CHANCEY! YOU DON'T KNOW WHAT YOU ARE GETTING.THE DRIVE IS PROBABLY RUINED ALSO. YOU ARE LOOKING AT A MAJOR REPAIR, REBUILD. YOU NEED TO START TO GET EVERYTHING COMPATIBLE, SAME VOLTAGE ETC. DO NOT PLUG HARD DRIVES IN WITH POWER ON OR UNPLUG THEM WITH POWER ON. THAT WILL DESTROY THEM. THE DATA MIGHT BE RECOVEABLE ON THE ONE DRIVE, BUT IT WILL MIGHT HAVE TO BE SENT TO A SPECIAL LOCATION TO RECOVER THE DATA. THIS IS ALSO USUALLY FAIRLY EXPENSIVE SO BE PREPARED. HOPE THIS HELPS.
Posted on Nov 01, 2008
Where can I get a replacement board for a Seagate barracuda 7200.7
You want to replace a board on a hard drive. I doubt that this is possible or that you will ever find one
Oct 14, 2014 | Seagate ST3120026AS - 120GB 7.2K SATA...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
No hard disk found......
You must first press f6 to load the SATA drivers for the hard drive before you go forward with the install.
Good Luck,
NOLA Tech
Feb 06, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Windows xp will not recognize my seagate barracuda 7200.10 although it is recognized in the BIOS. I pressed f6 during setup and it is asking about the Manufacturer-suplied hardware support disk. Where...
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
Jul 30, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
I want the disk manager for managing my wdc laptop hdd ?
Click on Start then right-click on Computer (for Vista) or My Computer (for XP) and select Manage from the context menu. Click on Disk Management in the left-hand pane. And here you are...
Jul 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
You need to get a new Hard disk. There is no way to get info off the Hard disk that won't turn in because theres probley a short a an element that failed and burned out. Hope this helped. =)
Feb 25, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
