Question about Whirlpool GU2400XTP Built-in Dishwasher
FAULT WITH DISHWASHER
My Whirlpool generation 2000 dishwasher is not very old,the plastic arm at the back that connects to the revolving arm that spins the water keeps coming loose and i have to snap in back in every time i use it? I have been using the diswasher since xmas time and this problem has started about 3-4 weeks ago. Any suggestions please.
  • duckegg1 Dec 23, 2007
    my pipe keeps popping out also and i have to keep popping it back in during cycle. My dishes are coming out semi cleaned and not drying. Any one no whats up.
    Novelist:
  • 148 Answers
Sounds like a design flaw.
i would talk to to the service center for a permanent solution.
this is a mechanical issue that should not be happening.
good luck
mark
Posted on Dec 28, 2007
What is error code F6 E5 in Whirlpool Dishwasher ADP 5510 IX ??? The dishwasher keeps stopping after 2-3 min of working.I haven't touched anything since the day I bought it (2 months ago)
Fault Code F5
Dishwasher Spray arms are clogged or otherwise malfunctioning
F6 Fault code
Dishwasher doesn't detect any incoming water despite the water inlet valve being open.
Nov 10, 2016 | Whirlpool Dishwashers
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
Oct 10, 2009 | Dishwashers
Can't remove lower spray arm
the nut screws off counter clock wise.
Mar 18, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
How do I open the sprary arm
the plastic screw is not holding it down. First disconnect the white tube in the back of the bottom spray arm.Now turn the stub part clockwise. and the spray arm should pop off...
Jul 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
No water or rotation to upper rack
if its not letting in enough water then this can happen.check water connections or a motor fault.
Jan 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool ADG 6340 Dishwasher
What flashing are you referring to ? This could very well be a fault code.
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Installing part
there should be a clip half way up the back and on the top. release those and the old tub should come out with out to much difficulty. the peice that attaches from the feeder arm to the lower spray arm turns clock wise and lifts out. the lower spray arm will unscrew if you use a pair of pliers.
Sep 24, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU2400XTP Built-in Dishwasher Logo
151 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
