Question about Bowflex Treadmill Series 7
Stutters my treadmill stutters so it is a run stop run
  • Peter Owens May 06, 2009
    Similar problem, mine won't hold a constant speed under the load of even a 60 Kg woman walking.
    Suggest investigating whether your machine will run smoothly under load at various speed settings. That will at least provide the manufacturers service people with more info if you choose to contact them which is a good idea. Oh yes one more thing check drive belt tension between motor drive pulley & front roller drive pulley. You will need to remove the front cover to do this.
    Peter O
I Have velocity Trade Mill. It,s Moter and circuit has failed twice recently it was sent to the company for repair. The dealer says that it may be due to voltage problem . I have got checked several times there is no problem. The dealer says that stabilizer of 3KV should be used. Is it necessary to use Stabilizer
Posted on Apr 19, 2011
    Genius:
  • 1,689 Answers
These types of faults can be in the motor, motor drive, controler, or in the velocity sensor (external or internal). If you call the manufacture, they should have statistics on the parts that fail most frequently. They would be the best guide to use for finding out what parts to order. You may have to try a number of parts to find out which one is actualy defective.
Jerry G.
Posted on Nov 01, 2008
My wife 140#'s can run on our F80, four years old. I, 260#'s can get on the treadmill and it stops and stutters... what is most likely problem?
if the numbers refer to your weight--simple --you are too heavy and the mat will not slide and the motor is overloading
run down the road til you get down to the max weight specified by the manufacturers
May 07, 2018 | Exercise & Fitness
I have a problem. Every time I try to run my treadmill the motor runs for roughly 2 seconds and then turns off. The power is still on, however, but the treadmill only runs in short bursts. How can I f
If it stops but you can still hear the motor running then I would check the belt tension. The force of you running could be causing the belt to stop but no the drive.
Dec 24, 2014 | Nordic Track Nordictrack C2100 Treadmill...
Belt problem ...
Hi Paula, I know nothing about it, you could lift the belt and use DW40 or vegi spray where it's squeaking. Nothing beats a walk in the park. Greg.
Apr 27, 2014 | Proform 680 LT Treadmill
Treadmill overspeed.
hi.
i think the problem is with your touch switch panel.
regards,
nuwan
Jan 20, 2014 | Vision Fitness T9550 Folding Treadmill
The belt is stuttering on treadmill when walking on it
1) LUBE the deck belt, this happen to due the lack of maintenance according with your instru.manual follow the step donwloa your instruction manual. go www.fitness.manualsonline.com or www.iconservice.com
2) LUBE the rollers bearing very well.
3) Tight with NOT much tension the drive belt.
4) Adjust the tension deck belt see the diagrams attached.
Sep 02, 2012 | Exercise & Fitness
Stutters at times while running. do I need to adjust belt and how do I do that?
hi,
Watch the following video which will help you to adjust the running belt of your treadmill.
OK
Aug 24, 2011 | Tunturi Exercise & Fitness
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
I am 230 lbs. and when I try to run intervals on the treadmill belt stalls out all of the time causing a stutter, and I almost fall down.
hi it seems like the running belt is too loose try tighten it. you should be able to lift the belt up 2 to 3 inches if more then def tighten the belt. after this if the problem is still there then the belt on the motor needs adjusting.
Nov 20, 2010 | Precor 927 Treadmill
Youtube video stops and stutters and buffers a LOT
Did you properly checked your internet connection and speed? if speed is ok then try to upgrade flash player. Hope this will help u.
Regards;
Hasan
Dec 30, 2009 | Compaq Presario 700 470024-192 Notebook
Why does my Ironman Triad treadmill motor slow when people try to run on it, the belt completely stops
When running or walking on my Ironman Triad Treadmill it jerks like it is going to stop every once in a while not all the time. Do you have any idea what makes it do this. I have had this Treadmill for 5 years and never had a problem before.
Dec 19, 2009 | Ironman Exercise & Fitness
Bowflex Treadmill Series 7 Logo
265 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
