Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa c250 evrytime i turn on this player..won't appear the display menu...help!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Database not refreshing, Could not listen the new songs added
go into your menu go into veiw all songs then go to play all
May 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Menu key is not operable
complain to sansa. use your warranty service.
Feb 01, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
The display of my SanDisk Sansa C250 is messed up
I think there is a language option in the Settings setup. Scroll down from Menu (music,radio,voive,photos,settings). Scroll down to Language. Select English or whatever. Worked for me!
Jan 22, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
No USB mode in Settings menu c250
Updating firmware video
http://www.youtube.com/watch?v=kVLoG4FWEjc
I can't access the menu and the MP3 is stuck on radio
I hit the right combination and the full menu appeared. It's just hit and miss.
Jan 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Scan disk sansa c200 series locked with an error message
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I need to know how to delete songs off my mp3/sansa sandisk c250
Open "My computer", then "Sansa c250 (E:)", find properties to show hidden files and a "Music" file (which is hidden) will appear. You can erase music directly from there.
Nov 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging the c250
Turn it off, and then plug it into charger
Nov 13, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Display prob
Is the screen cracked?
Does it appear to be leaking a liquid?
If so, there is no "fix" for it, you will need to have the screen replaced.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
