SOURCE: Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
SOURCE: 2 sided print on c534n
goes through below link and download the pdf file in page nuber 50 how to take duplex print....
www.bcplib.org/PDF/Manuals/Lexmark%20c530dn.pdf
SOURCE: How do i reset a lexmark c534n? It won't let me
There might still be paper in the machine.
Or perhaps a small torn off chip of paper caught on a sensor somewhere.
If you recently had a paper jam, make sure you cleared it properly, and did not leave any bit behind, especially if thpaper tore as you removed it.
Check all doors and remove the toner cartridge to look underneath it.
Good Luck
SOURCE: Lexmark E450dn has a clicking noise and jams evry
On the left side after taking the panel off, there is a mtal plate with alot of gears on it. behind that is a gear and clutch assy., this assy. needs to be replaced, it is recommended that you replace them every 30,000 copies I believe, but don't quote me. Hope this helps
When you say you're hearing a click noise, does it come from the back, front if the printer?
