MOTOROLA DCT 2000 SERIES CABLE BOX NEEDS TO BE RESET
BOX WILL ONLY SHOW CHANNEL ZERO. NEED TO RESET IT SO IT CAN RECIEVE BASIC CABLE CHANNELS. HELP IF YOU CAN PLEASE.
SOURCE: Digivox DV3 cable box
press edit and go to bottom selection system instilation, press ok. type in 1004 on remote, nothing will appear till last digit entered. you will now see a hidden menu. there are three selections go to the bottom one and highlight, to the left another box says off use the right button and it will change to on. press exit till you come back. Go to sky movies or sport and a few minutes later you will see a box updating data, let it update and a picture will apear, all the pictures are now unscrambled. worked ok for me.
Posted on Aug 31, 2008
  • 5 Answers
SOURCE: reset
using your remote hit replay-list-live tv 3 times each it will shut of reset then hit list & will read 0
Posted on Mar 28, 2008
centralhigh
  • 260 Answers
SOURCE: Need channels reset
If you do not have a replacement remote and their is no menu button on the tv then you will have to do a hard reset.
To do this you will have to unplug your tv and all connecting components until such time that the tv is reset. You will know it is reset when the tv asks you when you turn it on to run a channel program.
Good luck.
CH
Posted on Jul 29, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
My dch6416 will only display a zero?
Sounds like the program may be hung up. First try a hard reset which means you need to unplug it from the power strip. Wait 15-20 seconds, then plug it back in and see if that resets the program. If that doesn't help, try the 800 number that you used when you first turned it on out of the box. Lastly call your cable provider.
Feb 13, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
Motorola T5420 won't transmit to each other.
Since you say the frequency is set the same, you possibly have the code set differently. Check your interference eliminator code. It must be set the same on all radios. For basic operation turn the code off (zero).
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Best regards.
May 16, 2010 | Motorola Talkabout T5420 (14 Channels)...
TV will not turn on to channel 4 everytime. I have a cable box and need the tv to remain on channel 4.
As long as the tv is not unplugged it should stay on the same channel when turned back on. If you have the tv plugged into the cable box, when the box is shut off it basically unplugs your tv and the tvs memory is reset. The tv should be plugged in to its own outlet or leave the cable box on and turn off the tv. If you turn everything on, cable box and tv, and have a picture, go into the tv menu and auto program the channels, it should only lock in on channel 4 since it will be the only channel the tv will receive.
May 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
DCT6412 DVR Box
When that happens its most likley you had a power outage and the box reset.  Well kinda reset but not all the way.  You can unplug the power and wait about 10sec and plug it back in and wait a few min to a few hours, and If that doesn't work get a new box.
Oct 04, 2008 | Arris DCT6200 DTV Receiver
Up grading Fortec Star (Lifetime II) reciever.
my fortec star reciever is not up grading through (Action HBS link box) to open Showtime program
Apr 25, 2008 | Fortec Star Lifetime ULTRA
Televison & Video Logo
2,235 people viewed this question
Top Televison & Video Experts
Electro Med Services...
