Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Dishwasher leaves a white residue
After a wash cycle in a newer kenmore dishwasher a white residue is all over the dishes
    Genius:
  • 1,011 Answers
Dear Sir/madam,
One thing that wouldn't harm anything and might just work is filling the bottom of the dishwasher with white vinegar (you can buy a gallon for a couple of dollars) and let it sit overnight, then run it without dishes in the morning. Vinegar should dissolve the deposits.
also check......
Check your water temperature. The temp. should be at least 120 degrees F. in the dishwasher. You should run the hot water in the sink until it gets it's hottest before you start the dishwasher to ensure that you get the hottest water possible to wash the dishes. If you have the option select for heated wash and heated dry whatever their terminology is. The best advice for the hard water is to use jet dry there should be a dispenser for this on your dishwasher
thanks
good luck
Posted on Nov 01, 2008
    Genius:
  • 1,847 Answers
Seems like the drum is rubbing against something, just take a close look? and let me know what is that.
  • 13,433 Answers
It may be caused by what you use to clean the dishes try another brand or type.
also, if the dishwasher cleans poorly, check these things:
http://www.repairclinic.com/0088_9_1.asp#Level1_2
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 24, 2011 | Kenmore Dishwashers
We have had a white residue on our dishes and silverware after washing on both the high wash cycle and the normal wash cycle. What can we do to fix this? Thanks.
heatman101
Dec 23, 2010 | Thermador DWHD64EM Built-in Dishwasher
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher is leaving residue or soap scum on my dishes...
heatman101
0=0
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
My dishwasher leaves white residue on cups of the
heatman101
Feb 15, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
White residue on dishes after wash
check if the residue are soap or not. residue could be from water tank or water itself.
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
94 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
