Question about Dell Latitude D600 Notebook
Inspiron 8600 battery don't work
Weeks before i got a dell battery from http://www.all-battery.co.uk/laptop-batteries/dell-inspiron-8600.htm but it can't be charged!
    Genius:
  • Dell Master
  • 1,252 Answers
Check your power adapter
Posted on Nov 01, 2008
Tip
Http://www.discount-laptop-batteries.co.uk/sony-vgp-bps8.htm...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Feb 05, 2010 | Computers & Internet
Buy laptop battery fot your laptop,please go to? www.buy-laptop-battery.org
People's laptop battery store,the bigest and most special laptop replacement battery store hottest battery model http://www.power-battery.co.uk/laptop/dell/inspiron-6400-e1505.htm
Aug 07, 2010 | Dell Inspiron 6400 Notebook
My dell d620 laptop need a battery, I want buy one online, so everybody, how about this http://laptopsbattery.us/dell-latitude-d620-battery.htm ?
The one you have listed is for a good price but this one may be a tad bit better:
http://www.amazon.com/7200mAh-battery-Latitude-Precision-serie/dp/B001RNACES
Price is a bit better but its just knowing what the shipping is going to be.
May 28, 2010 | Dell Latitude D620 Notebook
I want to buy a Dell inspiron 1525 battery
Yes. you can go to that link,I cannot find anysite offering less than that with one year warranty even in Amazon.
I will also remember the site name for my future use.
Thank you.
Dec 28, 2009 | Dell Inspiron 1525 Laptop
Is any cheap battery for laptop d620
Hi - i've ran a D620 now running a D630 and yes the battery life is extremely poor even when the battery is new.
The option above will give you extra - you can also buy a moduler battery that will fit into the CDROM port which will give you even more!
http://www.google.co.uk/products?hl=en&q=d620%20modular%20battery&cr=countryUK%7CcountryGB&um=1&ie=UTF-8&sa=N&tab=wf
or ebay is your best bet...
Dec 31, 2008 | Dell Latitude D620 Notebook
Inspiron 1525 battery doesn't completely charge and a/c adapter not reconized. My laptop is only two months old so I called dell and they said I needed another battery and motherboard. I can't do wothout...
Update your power supply driver. There are some problem about dells power supply system. It also cant recognize the battery. If this cant solve the problem, advise you buy a new laptop battery replacement . Dont buy dell expensive OEM battery, see something in revive dead laptop battery in http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm or you can cheap replacement there.
Good luck.
Dec 14, 2008 | Dell F3534 Touchpad
Dell 1691p http://www.cheap-laptop-battery.co.uk/dell-1691p.htm
who gave you that link? you won't get it there, try here for your model:
http://www.cheap-laptop-battery.co.uk/dell-inspiron-6000-battery.htm
regards
Nov 22, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Latitude D600 Notebook Logo
112 people viewed this question
Alun Cox
