Question about Dishwashers
Telmann washing machine TEL6TL
When Ist cycle begins at filling stage, the machine stops and displays E2
Is this balancing arm? as I have read others have similar problems.
The balance dial on the top left handside of machine registers as balanced.
  • 2 more comments
  • Anonymous Jan 04, 2009
    I have the same problem, mine has E1 displayed. It is completely full with water and will not empty now, I can turn it back on and start the wash again but when it gets to spin it just stops and displays E1 i have taken all the clothes out but no luck- think im gonna have to get a new one
  • dideroy Feb 18, 2009
    the water won't empty out
  • peterwk Mar 05, 2009
    Washer fills then stops beeps and flashes E2. If I click through to spin, the water will drain, but will not spin. Stripped pump, but it was clean, and flushed out bowl. If I switch on and press wash and start the agitator will go for 7 seconds, then the machine will fill up ( to level 6) but stops when level reached and again I get the E2 code. Machine is 2 months out of warranty
  • app_3rp65261
    app_3rp65261 Oct 14, 2012
    My Teleman as of yesterday Will go through the first Cycle but it wont rinse... How do i solve this please????? I need my washing machine with 4 kids and 2 adults in the house
Telemann TEL6tl E2 Problem
E2 on screen means the lid is not closing properly and thus not activating the (hidden) switch that prevents the machine from spinning while the lid is up.
The lid switch in this model is not a direct contact switch between lid and switch , but it switches on and off due to a MAGNET embedded in the lid on the left hand side near the front. You will see a small indentation where the magnet SHOULD BE. My magnet had fallen off, so the lid could not activate the operation switch. I had lost the original magnet( about 1cm X 2cm) so glued another into place.
Machine is now fully operational again, and the job cost .78c.
If your magnet is still in place, the E2 fault could lay with the switch itself , which is fixed to the underside of the top casing of the machine near the front right hand side of the lid cavity. The switch measures 1cm X 3cm heavily black tape insulated. Access is gained by popping the 2 X2cm discs at front top of machine and releasing the 2 small philips screws here and a further 2 at the back top of machine. This operation of replacing the switch is best left to an electrician or washing machine specialist.
Hope that helps
Apostle95
Posted on Mar 07, 2009
  • 1 more comment
  • peterwk Mar 07, 2009
    CORRECTION re E2 by Apostle 95
    The magnet in the Telmann TEL6tl is on the RIGHT HAND front side of the clear lid NOT the left as incorrectly written by me earlier. The switch is directly below the magnet ( or its cavity if magnet missing) and the position may change over models.
  • gina74
    gina74 Mar 28, 2012
    I LOVE YOU Apostle95...THANK YOU!!!! I found the magnet sticking to inside of drum and thought hummmmm did my man have stuff in his pockets again? or is this part of the machine? Must have tried to start machine one million times. Thank you,Magnet back in place and ready and waiting to hang the laundry out. Good Man!
  • Mow Mow
    Mow Mow Jul 29, 2016
    thank you so much for your advice been without washing for a whole week until I finally decided to google it your answer worked.
Where abouts duz the E2 being displayed on the washing machine.....my washing machine doesnt spin only if i take clothes out it will spin...
Posted on Dec 07, 2010
No drying
Posted on Oct 30, 2010
My machine is leaking water now when ever its filling up with water
Posted on Jul 11, 2012
Um mine just went on fire this morning! Put out the fire and had a look underneath and the whole electrical system is burnt out!
Posted on Jun 09, 2010
Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
Jun 19, 2012 | Washing Machines
Hi..Telmann tel6tl displays fault code E3..have you any ideas.. Thanks.
HELLO.
This code (E3) means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping if noted then .
  • Reprogram the Washing Machine.
  • If the code still displays, turn off the power to the Washing Machines at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on for operation.
Thanks for using fixya.
Jul 31, 2011 | Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
The washing machine starts ok and fills with water. However, it quickly begins to intermittently cut in and out whilst filling with water. It does this for a while before stopping completely. I've tried...
you did not mention the type of machine but for top loader the most probable cause of your issue is the door /lid switch that is in need of adjustment as most top loaders will fill with the lid open but cycle cant start or continue when the wash thinks the door is open this is a safety feature
Aug 14, 2010 | Washing Machines
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Will not move to the next cycle.
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Washing machine wont stop filling up
    check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
    Oct 18, 2007 | KitchenAid KAWS750L Top Load Washer
    Dishwashers Logo
    2,776 people viewed this question
    Top Dishwashers Experts
