Question about Cameras
I have a compactflash disk that my camera will not recognise. I have placed it into a Windows XP PC but this will not recognise it either.
    Novelist:
  • 208 Answers
MOST LIKELY YOU HAVE EITHER A COMPATIBILITY PROBLEM OR A BAD SD CARD. SORRY, BUT IF BOTH DON'T RECOGNIZE IT SOMETHING IS REALLY WRONG WITH THIS FLASH CARD. THEY DO AND HAVE BEEN BAD OUT OF THE PACKAGE. IF IT'S NEW, I'D TRY TO RETURN IT. IF BOUGHT ONLINE, MOST VENDORS ARE PRETTY GOOD ABOUT THESE PROBLEMS. HOPE THIS HAS HELPED!
Posted on Nov 01, 2008
Computers read my SanDisk compactflash a 128Mb. I checked the card and it doesn't work ok in my camera.
connect it to the computer... then go to disk management and format & redefine the simple volume of disk again.... it might work
Mar 18, 2013 | SanDisk Cameras
Formattting again and again my SanDisk Extreme III 4.0 Gb CompactFlash Card
Hi, It may be possible that your CompactFlash Card is nearing its end. You can try formatting it after you have downloaded into your PC all the pictures. Try to use the camera's built-in formatting function. Thereafter plug it back to your PC and use a disk checking utility such as scandisk or Norton Disk Doctor. Do an intensive check including the free space. If the disk check shows any errors, then the CompactFlash Card is no longer a reliable storage media and you are better off purchasing a replacement rather than gamble that it will still work. If for some reason, even your PC can not access the card, you have to use a file recovery program to recover/download/copy the picture files and then try the disk check utility. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 09, 2007 | Cameras
Windows XP won't recognise the camera
Let me know if this helps: When a mass-storage class (MSC) Luminx camera is connected to a Windows XP system the camera does not appear as a mounted drive if there are no free drive letters between physical drives and mapped networked drives. Remapping the first network drive and leaving a free drive letter solves this issue. For example: If the Floppy Drive is drive ?A? the internal Hard Disk is ?C? the CD-ROM is ?D? and the mapped network drive is ?E? the Lumix camera will not mount. If the mapped network drive is moved to ?H? the Lumix will mount properly as drive ?E?. To change the drive letter mapping: Find the mapped network drive in the "My Computer" Right Click the drive and choose "Disconnect" Use the "My Network Places" to find the share to be mapped (that was removed above) Right click the shared item and choose "Map Network Drive..." Choose a drive letter from the pop-up list, remember to leave at least one free letter after the last physical drive Click "Finish" the share will now be mapped to the new drive letter and the camera should mount As long as there is a free drive letter between the last physical drive and the first network drive the actual letters do not matter. For instance if there were more than one hard drive (or DVD, CD-R, etc). This issue has only been documented with Windows XP and MSC class cameras, cameras capabale of using PTP USB mode should be set to PTP to avoid this issue.
Sep 05, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
Can't install XP service pack2 on my AcerPower f6 computer.
Did this machine have Vista intalled originally? I checked Acers' support page for your model and I didn't see a xp sata driver.
Apr 14, 2009 | AcerPower 1000 (AP1000EA380M) PC Desktop
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
I cant install windows xp
In the bios, look and see if there is a place to make ide or ata active. If not, then you will have to slipstream the SATA drivers to a new installation disk.
Mar 18, 2009 | Compaq Presario C700T Notebook
Hooked up my PC with 2nd Hard disk, a MAXTOR 6L 160 MO Hard drive , but Windows XP SP2 does not recognise it, i.e it does not appear in MY computer. However it is recognised by the Device Manager in...
try open computeradministration.
go down to disk handling. If you can see it there you can format the disk and what way get it to be shown.
CS.
May 20, 2008 | Computers & Internet
PC Connection problems
Simply disconnect the camera, Restart the computer. See what happens. If no go Do a restore to a day before the incident. Come on back Also if you have Casio software loaded -remove it - Windows can do with out that.
Sep 26, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
