Question about Alpine TDM-7561 Cassette Player
Security code for Car Radio cassett Alpine 7510T
We changed the battery so need to reset
  • basementguy Feb 11, 2009
    Same as above.
  • Anonymous Feb 20, 2009
    Just purchased a car with this model cassette radio. Red light flashes, but can't turn on to get display. Is it wired in and if I need a security code how do I get one and enter it?
I have a manual for this type of stereo and it states:
Turn ignition switch to accessory position and enter code: 2 3 3 5 6
I have tried but not had any luck!!
Posted on May 09, 2009
Do i need to power down to change the back up battery
If this is ordinary residential timer, you can replace battery without changing anything.
Just replace battery.
Most timers will hold some or part of the memory during battery changeover... frequently losing no programming if battery change is done quickly, and battery was not completely depleted, and timer is still functional.
If timer function is not restored after battery change, reset timer fully and then reprogram.
If battery change and reset does not work, then timer is probably gone bad.
Most modern timers have reset button, but some require a 2-button sequence to reset.
Other modern timers have a 'battery' but the battery is built into the circuit board and thus not replaceable ... it is rechargeable, like a capacitor ... but when it fails .. the timer needs to be replaced.
Timers with replaceable batteries are generally not functional after exposure to freezing temperatures for several day, but the non-replaceable type generally have wider tolerance for temperature variation.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html
Gene
Water Heater Timers Save Money
Mar 23, 2015 | Hardware & Accessories
Abs,tc&brake light stays on after changeing battery
I would disconnect the negative cable on the battery so it can reset the abs module, on these cars when you change the battery you need to have a 12 volt supply connected to your lighter before you disconnect the battery so there will be no reset on any of the modules in this vehicle.. if that don't do the trick you need to scan the abs system to see if you have any hard codes or just to reset it with the scanner.. abs is for antilock brake system and tc is for traction control they both work out of the same module
Jul 19, 2014 | 2005 Buick LeSabre
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
May 06, 2014 | Mio 0021usblk2 Drive Petite Hrm Black...
Battery needs to be removed, will that change electrical systems; ie need to be reset by mechanic?
I have never had or heard of any battery causing any issue other then having to reset radio preferences when being changed/pulled/cleaned. You can buy battery terminal cleaner and protector at your local parts store. And yes in time acid will corrode any thing it touches except certain plastics.
Jan 26, 2013 | Cars & Trucks
Power steering pump is not working and i need to replace it but sumone side i need to reset ecu how do i do that its 2001 1.4 peugeot 307
The ECU shouldn't have anything to do with changing your power steering pump. If you want to reset it and definitely need to change the pump, Kill two birds with one stone. Disconnect the battery while you change the power steering pump. When you're finished changing the pump, sufficient time will have elapsed so that when you reconnect the battery, the ECU will be reset. Just bear in mind that when you do this, any devices that use a memory (radio presets, clock, etc.) will need to be reset to your preferences.
Jun 26, 2011 | Peugeot Liberte Cars & Trucks
Mge galaxy 3000 how to reset battery expire alarm after battery change
Unfortunately the reset is only possible with MGE software (Softunor).
Jan 24, 2011 | MGE UPS Galaxy 3000 UPS System
Change the battery it will not work
IF BATTERY DONT WORK, BATTERY CABLES IF THEY ARE OLDS AS VECHICLE REPLACE THEM. SEE WHAT HAPPENS.
Dec 30, 2010 | Suzuki Vitara Cars & Trucks
After replacing the battery, the doors and liftgate will not open with the remote.
This sounds like you need to reset the fuse for these features. this is similar to oil changes on newer cars, after the change is done, a fuse needs to be pulled and put back in to reset the system of the oil light. I'm only shooting a guess here, but if all that was done was a battery replacement, the system was 'reset' when the battery was removed. Check the fuses.
Dec 11, 2009 | 2005 Mercury Monterey
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Oct 20, 2008 | Fuji FinePix F700 Digital Camera
Hard reset screen appears whenever i change the main battery
Your pda has a built in battery.The inbuilt one has lost its charge. To keep it from reseting to its original factory settings. You need to keep the main battery(the one you charge up) regularly charged.
Feb 14, 2008 | Dell Axim X50 Pocket PC
Alpine TDM-7561 Cassette Player Logo
1,947 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
