Question about Miele W864 Front Load Washer
Mile 864 front loader - clothes come out with new grease marks
Hi my Miele has started turning out shirts with grease stains on cuffs and collars (no ,arks ar they go in) On the underside of the rubber seal, there was a slimmy/dirt/oil all way around teh cylinder. Cleaned this off, buit still getting spots Does anyonne have any ideas where the dirt build up is and how to get rid. PS we have tried running through a hot cycle with powder and no clothes thanks tony
  • stain fighte Aug 03, 2008
    Yes, I too have been greasy type marks on some of my clothes. I have not been using any fabric softener and it doesn't seem to matter if I use cold, warm or hot water washes. Out of one load, only one shirt will have a stains on it??? I have run a complete cycle using bleach and the temperature boost cycle. Once the stains are on the clothes they are impossible to get out.
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Posted on Sep 04, 2007
What is turning
Could be a couple of things.
If you are sewing a new collar, turning is done after you've sewn three edges together and then you turn the item so the right sides are out and the raw seams are enclosed inside the collar. Then the collar is attached to the garment using the fourth (unsewn) edge.
https://www.craftsy.com/blog/2013/12/sewing-perfect-collar-points
How to Sew Collar Points Melly Sews
Or turning on an old, worn garment is when the collar or cuff is unstitched from the shirt and then flipping it over so the worn part is on the underside and the fresh, clean part is facing up (as against the neck edge or, in the case of a cuff, against the arm). This is an idea from the depression era when people wanted to get more use out of an item that was showing wear.
Turn shirt collar
Oct 02, 2016 | Sewing Machines
My miele w3725 front loader washing machine appears to be leaking drops of oil into the wash and staining the clothes. What could be the cause?
Hi dear,
Seems like your washer has bearing seal damage. It will be expensive repair. You may contact Miele to get a quote. Thanks.
Jan 01, 2016 | Miele Washing Machines
How to remove grease stain from laundered shirt
How to Remove Grease Stains ' Stain Removal
www.howtocleanstuff.net > ... > Clothing & Fabrics > Stain Removal
Begin by blotting with a clean cloth to remove as much of the grease as possible. ... If your clothing is durable, spray oven cleaner on the stain and let it set for ...
Oct 07, 2015 | Washing Machines
My clothings get grease like stains sfter I wash them with Kenmore washer.
Don't know if this is a front or top loader since you did not supply the model number. But if the stains are grease, it could only mean that the bearing seal has been compromised. Water is getting into the bearings and the bearing grease is what is on your clothes. You need to have the bearing and the seal replaced on your machine.
It is not to bad on a top loader in terms of cost to repair. But, if you have a front loader, that is a different story, since the entire machine needs to be torn apart to get to the bearings and the replacement parts and labor can be as much as a new washer. In either case, get a few estimates before deciding whether to repair or replace the washer. Hope this helps you.
Jan 08, 2011 | Kenmore Washing Machines
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
For some reason, my washer is now starting to leave rust color stains on my clothes. Not on all clothes but only on the corner areas of clothes like the tips of the collars on mens shirts or the small...
If you wash your clothes with warm or hot water, try using ONLY cold to see if the problem goes away. Sometimes older water heaters start to produce rusty-colored water as they age.
Jul 12, 2009 | Kenmore Washing Machines
Stains on clothes
Check the fit of the agitator to the bottom of the drum. After this many years, it may have warped up to make a gap. Run a rag around the joint to see if it marks.
Apr 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
STAINED WHITE T-SHIRTS, DULL LINEN
Hi! I am a habitual cleaning type person and clean clothes rate at the top of my list. I have 4 recommendations that SHOULD help tremendously for ALL your clothes but is most evident in your whites.
#1 is the right washer. I NEVER knew how clean my clothes could come out till the past year and a half I finally bought front loader. And let me tell you was I ever surprised at how clean and soft they were, LIKE NEW! Those old top loaders,even the new ones are no comparison to the front loading systems. BUT expensive if you have to go out and buy a new one BUT also a GOOD excuse to tell hubby you need a new one...LOL
#2 Always use liquid detergents, they seem to wash and rinse out so much better than any powder
#3 A HUGE helping hand I discovered some 30 years back that I STILL have not found that can be beat is "BIZ" bleach. It's miraculous! It's a great pre-treater to soak badly needed whites in and helps to retain bright colors if used in non-white laundry. Actually I even use it in a powder form. AFter loading all my clothes in m y front loader I scoop out a cup and actually scatter it OVER my laundry. Then add the liquid detergent (Tide or the like, I get mine at Costco or Sam's club depending on what region you live in) and wash like normal.
#4 Last but not least, for whites and ALL colors I have found nothing better than DAWN dish washing liquid. Immediately pre-treat ANY stain no matter the size with Dawn and just fold it over and toss it in the laundry. Best if washed within the same week at the latest.
GOOD LUCK to all you Domestic Goddesses! ;-)~
Jan 19, 2009 | Washing Machines
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Miele W864 Front Load Washer Logo
604 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
