Question about LG LSC26905TT Side by Side Refrigerator
Foul odor there is an awful smell from the outer lower portion of the fridge. is there a water drip pan somewhere
  • sugargirl120 Jan 05, 2009
    My fridge is also stinking, can't find the problem. We've cleaned everything and no luck.
  • Anonymous Mar 15, 2014
    awful smell how do I find the drip pan?
    Problem Solver:
  • 10 Answers
Yes ,there is a condensate drain pan in the compressor compartment under your unit.
You should be able to get to it from the rear of the unit, by remove several screws.
Use caution and unplug unit before attempting any repair.
The pan can be cleaned out with warm soapy water.
Posted on Nov 01, 2008
SQD26VL side-by-side has a fishy odor. Where is drip pan?
The drip pan is outside the fridge I believe, sitting in the back panel.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
A horrible smell from underneath 60721. The drain doesn't seem to be clogged. We think turkey drippings spilled and attempting to cleaning the drain and drain pan, but it's difficult. Is there a secret...
The drain pan may be accessible from the back. An equal portion of bleach and water should kill the smell. Make you wear gloves and use a fan to ventilate the area before and after using the bleach solution.
Dec 12, 2010 | Kenmore 60721 Refrigerator
Odor in my home
There may be mildew on the condensor (the big radiator inside the attic) and/or the water drip tray underneath it may not be fully draining causing the odor.
Your senses get "used" to the odor. Your brain will mask it so that you will be able to sense other odors.
Replace the return air filter more often. clean the airway taht the filter covers. Spray Lysol will help temporarily.
You must check the condensor & water drip pan.
Sep 28, 2009 | Heating & Cooling
Odor
Could you possibly have a dead rat under there? I know this sounds gross, but they love to hide in the electronics. (Sorry). Anyway, your drip pan may sit on a small bracket type piece that isn't heavy at all. It can sometimes get misplaced, causing the fridge to leak because it's out of place. If you can get a flash light, you should be able to see where it's placed and you should be able to remove and clean it out. I put Mr. Clean in mine when it gets an odor and when water hits it, the solution cleans the odor, but you can clean it and replace it. I hope this helps!
Aug 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
I have an odor cause my fridge has been closed with no power
yes drain pan is located in the back on top the compressor....10:1 solution of water and bleach is good enough to clean it with....kills mold and mildew....also remember that if the fridge lost power and found cause a stench inside, could be held by the plastic....ive been using dryer sheets in my units to help with odors. may take a few weeks...but a new dryer sheet a week helps.
Jun 12, 2009 | Refrigerators
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
LG LSC26905TT Side by Side Refrigerator Logo
564 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
