Question about Sony KV-32V68 32" TV
Sony Gurus! My set has sound, screen takes long to come on.
My KV-32V68 screen takes longer than usal to come on. VHS or DVD had same problems. The audio comes on right away. The red LED (power light) flashes anywhere from 7 (when TV is warm) to 30 when cold (overnight). I guess the number of blinks tells you what general areas to look at. The problem progressively got worse to where the screen was blinking on and off even when TV set was on for few hours (warmed-up), inaddition of picture color was phasing in and out with strong green hues. Tapping/slapping the set did not help. Took the back off to clean and inspect for loose connectors, cracked boards, leaking caps, etc. Didn't find anything. I did find a two adjustments ("Sharpness" on top screw and "Screen" on the bottom) on what looks like a transformer. I started to tweek the screen adjustment to the right and screen came on and stayed on, noticed that further adjustment to right made the picture contrast fade with green tint and with blue horizontal lines appearing towards the end. Adjusting to the left made the picture contrast darker and followed by total dark screen. Adjusted to happy place where picture wasn't going out (no problems for 2 days so far!). I'm sure there is something going out on this set as it take long tome for the screen to come on. Maybe some caps,power supply, or some board are going out? I'm guessing that whatever is going bad is not holding a charge like a Cap or inadiquate power supply to the caps? I did find the service code page but don't know the setting requirement as I don't have the serice manual for this set. This set has very nice picture quality and I would like to keep/fix it myself. I did see a repair kits (depending on the number of flashes) on-line but not sure if it's right for this problem. Everyone, including my wife is telling me to buy a new big screen HDTVs! I still want to fix this set, instead of dumping in the local landfill for $10 when the screen finally goes out! Please help with this repair! I have access to a nice PACE soldering station, and other electronic repair tool/equipment.
    Sergeant:
  • 337 Answers
I will suggest you put the screen control back to where it was,the unit has a lot of loose conections in the power supply,horizontal driver transformer and possibly crt board,if you keep using it like this it will go dead completly and the repair will be more expensive,be safe and call a person who is qualified and get an estimate.
Posted on Sep 18, 2006
  • Omar Urrutia
    Omar Urrutia Sep 18, 2006
    You are welcome!
I have a sony tv model kv-32s26 and the scrren turns off and on every 10 seconds ..i think the screen no longer works ..my question for you is...can this problem be solve without having to buy another...
If the screen does the same thing with all sources (TV,VCR,DVD), then it is most likely the main control board. The cost to fix or replace it would be more than the cost of a new tv.
May 13, 2011 | Sony KV-32S26 32" TV
Watching tv/w a dvd/vhs player(a seperate machine)the power goes out on the screen.went out with a white flash like usually when i turn it off.now on the bottom where the control buttons are,a red light...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
I have a UK sony trinitron kv-32wf1u with Black Screen
it could be one of the closed-caption settings. make sure the cc is off. if the problem remains, you may have tuner issues.
Jul 31, 2009 | Sony Televison & Video
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
Dec 26, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Picture goes off but i have sound
I got KV 32ts 46 Sony
Turn on TV and seems OK, then no picture but have sound. I turn it on and off some time pictures come back but goes out again. Pleas help
Oct 19, 2007 | Sony KV-35S40 TV
Cant access input jacks
Go into the setup menus IE:Video,Audio etc: The last page has the video label option. It is there where you select the label you want to give such as VHS,Beta,DVD etc. You can also select SKIP and that is why you can't access those inputs. Select any label besides SKIP and your issue will be gone.
Apr 23, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony KV-32V68 32" TV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
