-   Hello Jrallen,
I've just plugged in the cable line to my '98 Sony 35" TV with the new indoor antenna (Philips). It comes with a 75/300 ohm Transformer...The instructions are vague to this lady on what to do with this little accessory. Can you help me? Thank you so much!!
Barbara
-   Recruit4u02
Yes this set was top of the line back then as I repaired tons of them. These days its going to most likly cost you 250 to 300 bucks to repair this as it sounds like the flyback transformer and the horiz. transistor are bad, along with most likly a few dryed up capacitors. I would not invest anything into this set, but you are the owner and you have to ask yourself "do I want to invest in a set that your not sure what else will go bad?" Invest in a shiney new flat panel or a microdisplay set.
I have a Sony Wega Trinitron CRT 36" HDTV(KD-36XS955). I bought this 4-5 years back and all has...
(More)
I have a Sony Wega Trinitron CRT 36" HDTV(KD-36XS955). I bought this 4-5 years back and all has been fine. I have noticed recently that the screen looks like it's bowing down on the sides. It's especially visible when viewing something in widescreen format as you can see the black bars clearly bend downward on both sides. There are also 3 horizontal black lines that i think might be dead pixels? these lines are barely noticeable, but once you see them, they get annoying. any help would be appreciated.
Thanks,
Andrew
TV will not turn on, makes the initial noise like it is turning on, then can hear it click off, and...
(More)
TV will not turn on, makes the initial noise like it is turning on, then can hear it click off, and red light flashes several times
I have a 36 wega the picture comes on and goes out and stand blinks 6 times. sounds like power...
(More)
I have a 36 wega the picture comes on and goes out and stand blinks 6 times. sounds like power supply any suggestions Hi I have a similar problem with my 5 Year old Sony KD-36XS955 with black lines covering the bottom half of the picture where the top part of the picture is "prefect". The lines started 1 or 2 inches from the bottom and increased to 1/2 way after a couple of days. The stand-by light blinks twice and repeats after 5 seconds. Please help... Thx!
plug i smelt that smell like something burt ,since than i cannot get it to autoprogam channels but...
(More)
plug i smelt that smell like something burt ,since than i cannot get it to autoprogam channels but the kids can play games just fine and it will play movies from a dvd or whatever ,and letters and screen is still blue it just will not get reseption or progam channels
