Question about RCA F27628 27" TV
Channel selection woes continue!
Based on the info I received here (I really appreciate the quick response!) I tried to access "Channel Scan" or anything like it on the MENU, but was unsuccessful. The remote is actually for the DirectTV Receiver, but is programmed to work for the tv as well. Channel 3 is only channel on tv that comes on and it will not allow a change. The Manual channel buttons DO work and the channel number appears on the screen, but the channel will not change. I have also tried to do this manually by accessing the MENU from the front of the tv. What to do now?
  • Anonymous Jan 05, 2008
    How do you change the input selection from channels to the video inputs either on the front or the back of a F27628 TV? I can change channels, but cannot get the TV to recognize a DVD player using the red, white and yellow composite video input jacks on the front or back of the TV.
  • Anonymous Feb 22, 2008
    I have a RCA 27" TV model #F27227EM chasis #CTC169CF2, and it will not stop scanning through the channels, even when I use the remote and or the buttons on the television itself. Any solutions? Thanks for your help!
    -Concerned television viewer
    President:
  • 3,130 Answers
Sorry but your going to need to get an original remote from a friend or relitive to program this set. They sell rca universal remotes for 10 to 15 bucks that will work for you too.
Posted on Sep 18, 2006
I need a channel access code for a Westinghouse model VR5535Z
try this...
Contact westinghouse Channel Access Service by:
web: www.westinghousedigital.com/support;
select Channel Access and enter Access info.
Text Message: Text Tuner to 95495
Phone:1-800-701-0680 follow instructions
Jan 22, 2018 | Westinghouse Televison & Video
Im trying to set up an RCA antenna on my Hisense TV and can't get the channel scan feature to come up. What do i do?
Are you on a t.v channel or an input? Many t.vs won't access channel scan if you have one of the inputs currently selected. Once on a channel activate the channel search feature
Oct 29, 2016 | RCA Televison & Video
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
Hooked up the tv to my existing cable and it will only receive 15 channels. All my other tv's receive many more like 100 +. I did the auto detect when I hooked up the tv and 15 is all it detected.
This is a fairly common issue, either the TV has the upper channels blocked or the signal in that room is just not as strong so a quick scan is passing them over. I will give you the steps to remedy both issues. If the channels show up weak or snowy or not at all after trying these steps you may need to install a booster where you current line splitter is but try these steps first as the TV can easily compensate for a slightly low signal.
Enter the TV Menu, Select TV, Select Channels, Select Master List. Look for channels with X beside them, if they have X they are blocked, simply move down the menu selecting each one to remove the X.
Now that you have verified or corrected your master list select Turn on Additional Scan from the scan menu and run a new scan. The additional scan will take a lot longer but will take more time on each channel and should find them even if the signal is a little low.
Hope this helps FixYa,
Chris
Jan 04, 2011 | Vizio M220VA 22 in. LCD HDTV
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
How do you do a channel search on a 32LC50C ?
Press the Menu button and go to SETUP. There is a quick scan selection that will detect both analog and digital signals. Or if you are using a optional receiver (digital), it will lock into the channel, most likely channel 3, to display the signal. I hope this helps.
Jun 21, 2010 | LG 32LC50C 32 in. LCD TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
No sound of voice, only surround sound
If you do not have a center channel speaker connected, then in the reciever setup menu for speakers, there should be a selection for center channel that says something like either yes or no. I'm guessing it says yes. Then you need to select "no" so that the circuitry will direct sound specified for the center channel to be reproduced through your front speakers.
Dec 07, 2009 | Pioneer VSX-D711 Receiver
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
RCA F27628 27" TV Logo
96 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
