Question about Honeywell Programmable Thermostat Heater
Model ct3600 thermostat not working
As I was setting tempertures, I hit run program and it continued to say set program. I then tried to replace the batteries and now I have nothing on the thermostat. Any thoughts. We did try to reconnect the wires and that did not do anything. The screen is still blank
    Problem Solver:
  • 17 Answers
I know it sounds simple but the batteries are probably in the wrong direction. If they are correctly installed and fresh you will usually get a display.
Posted on Nov 14, 2008
  • johnsdsl Nov 14, 2008
    of course when you tried to reconnect the wires you may have burned your transformer out or popped a fuse. If the R and C wires touch for even a split second this is usually the case.
    Digital Thermostats are just small computers and they do break. When they do, the problem can manifest itself in any number of ways; erratic operation and just acting wierd can be some of them.
    If you have 24 or so volts to your thermostat from the transformer and/or fresh batteries or a circuit back to the common side of the transformer then the thermostat display should be showing...if no joy and you are sure there is power to it then I would replace it.
I need to clear the program in my Honeywell model # CT3600A4
OWNER?S GUIDE
Honeywell CT3600/CT3697
PROGRAMMABLE THERMOSTAT
9k=
Dec 26, 2014 | Heating & Cooling
Clear out all setting?
There should be a teeny tiny hole in the face of the thermostat for a paper clip to be inserted for clearing all programmed data and taking it back to the factory parameter settings. If not on the face, it should be on the circuit board and may even be a micro-switch.
Dec 26, 2014 | Honeywell CT3600 7 Day Electronic...
Honeywell thermostate will not kick off on set temperture
There's a "throttling range." The unit starts (say, in heating) one degree below setpoint and shuts off two degrees above set point.
You can change the "temp" but you can't change the throttling range.
Mar 02, 2014 | Honeywell Programmable Thermostat Heater
Hunter set and save prorammable thermostat 44155 want shut off at desired temperture. I have the thermostat set at 80 during the daytime when I am not home and 78 for evening and night. The thermostat will...
Possible that the sensor is not reacting and so does not set to the data required in the program. Try and see what is the error factor for the switch on and off which will give an indication of the sensor error. If so this must be replaced. otherwise you can use the error to set it likewise., higher or lower.
Sep 29, 2011 | Dryers
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
Need to set differential on my ct 1540 thermostat, the furnace kicks on at after it drops 1 degree this cant be right
Yes this is probably correct the newer thermostats will kick on with a 1 degree temerature drop. This is better since the furnace only has to make up one degree of temerature and has a shorter run cycle saving you money.
Dec 24, 2009 | Honeywell CT3600 7 Day Electronic...
Honeywell CT3600-AC not working
could be froze up if it is turn it off to melt ice clean unit could be low on freon or bad blower motor
Jun 17, 2009 | Honeywell CT3600 7 Day Electronic...
Heating & AC thermostat problem
It could be running in a "programmed mode" if it has the capabilities. You could exit from the programmed mode
Mar 29, 2008 | Computers & Internet
Heating & Cooling Logo
119 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
