Question about Toshiba 61H71 61" Rear Projection Television
The red power on light just blinks. Tried leaving it unplugged. Still didnt work
Toshiba 61H71 power on blinks. No sound. No picture. Was working fine yesterday. It seems there are others with tis same problem.
  • Anonymous Dec 23, 2008
    Light started blinking with no power
  • Anonymous Mar 03, 2009
    I have the same issue but could not find any answers or solution anywhere in the web. Anyone out there.
  • 3 Answers
Ours was doing the same thing, we changed 3 little black fuses in it and it works. I do believe they are 5 amp but not positive, we found them through a tester. When I have the exact answer for u I will email u again sorry u have had no response till now probably does you no good now..It's been awhile since they were changed.
Posted on Mar 24, 2009
Why is power light blinking
is it yellow as it blinks or red? if yellow check the kill switch located at the base of the lamp compartment cover ensure it presses the switch lever in order to ser the tv to standby mode the yellow blinking will stop and u will see a stable red ready for switching on
Jul 19, 2013 | Toshiba 61H71 61" Rear Projection...
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
What's wrong if the power light keeps blinking and there's no picture or sound. I tried unpluging it and it didnt work.
Unfortunately, your set has had a failure in one of it's components and it's safety circuits are keeping it from turning on fully. Contact your local TV repair shop for more advise. If you can take the set to them, it can usually save you up to $100 or more on your final bill.
May 06, 2010 | Toshiba 65H83 65" Rear Projection...
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Power light blinking RED after power outage. Tried leaving unplugged for a while. Continued to blink RED after plugging in again. No picture. No sound.
replace the power pcb,check the fuse on the
power pcb and see if that corrects your problem.if not replace the power pcb.go tp
shopjimmy.com to get the board.
Jul 29, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
My philips 37in lcd hdty model # 37pf7320a/37b will not turn on. Green light comes on for a second then a red blinking light. ive tried leaving it unplugged for a few hours but that didnt work. any ideas...
this sound like a power board problem they are nt that expensive if you do i yourself or a coud tech can fin what is exaclty worng on the board and fix or you cn cange the whole thing.
Nov 07, 2008 | Televison & Video
Cannot see picture....
you probobaly. need a new bulb, my dad had the same problem. he orderd a new bulb off the internet and now it works just fine
Apr 22, 2008 | JVC HD-52Z575 52" HDTV
Blinking power light
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Nov 18, 2006 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
301 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
