Question about Kenmore Freezers
Freezer light on but not running
I haven't used my freezer in over a year. I plugged it in and the light comes on, but it isn't running. I left it plugged in over night and still nothing. It is over 5 years old but under 10 (I can't find the manual)
I tried tapping on the thermostat - nothing. Any other ideas??
Posted on Nov 01, 2008
    Sergeant:
    Champion:
  • 324 Answers
Try tapping on the thermostat, it may be stuck open.
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Frigidaire freezer ffu14f5hwg red light on
It isn't reaching temperature. The red light comes on at -12c Check the condenser is clean, thermostat set ok and compressor humming nicely
May 22, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer wont switch off
Needs new thermostat. If trying to switch off and compressor still running, contacts stuck together. Many freezers run like this for years!
May 03, 2012 | Freezers
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
My Magic Chef 5.5 cubic chest freezer with manual defrost, just quit working. It was a year old this March and it stopped working this July. The power light is on, but run light is not. We unplugged for 5...
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
Oct 30, 2017 | Magic Chef Chest Freezer MCCF5WBX
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
My freezer is about 2 years old, but has been in storage for about a year and a half. The green light comes on, and the motor is running, but it will not get cold or even cool.
Hi ndntwiggy,
Ngafm at your service
Your said,your freezer is about 2 years old, but has been in storage for about a year and a half.
And the green light comes on, and the motor is running, but it will not get cold or even cool.
When a compressor is not run for more than a year, or 2 years there is a possibility that the seals dried out from non use and the freon leaked out.
Compressors have oil in them that when run even once a month will lubricate the seals and keep them soft and moist! .
Just like in the older cars from the 1960's or 70's the air conditioners had to be run once a month even in the winter to keep the seals lubricated or they lost the freon!
Then they started to make the defroster turn the compressor on as to lubricate the seals every time it rained or snowed and you needed the defrosters and this serviced the compressor as in todays cars.!
So you need service to fix it and more than likely it's out of freon refrigerant .
Let me know your end results.
ngafm
Please give me a good rating for my accurate advice,
before you sign out of our site.
thank You ngafm
Sep 09, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
82 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
