Question about SanDisk Sansa e250 MP3 Player
Sansa i have the sansa fuse and there my nav wheel just slows down, sometimes stops working, and then sometimes speeds up. why does it do that? how can i control it? in my settings there is no nav wheel seting so what do i do?
  • 8,596 Answers
unplug mp3 player from pc
uninstall the Sansa software
reinstall the sansa software
replug the mp3 player
-Tha Mp3 Doctor
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
How do you record FM radio on Sansa Fuze?
OK, while in radio mode, press the bottom of the wheel, scroll down to 'Recording', then select 'Record Now'.
(I have a Sansa Fuse too, so, i know my way around it.).
this should help.
Jul 22, 2009 | Audio Players & Recorders
Freeze on goodbye - Sansa e250
make sure to turn off hold/lock
-Tha Mp3 Doctor
Oct 22, 2008 | SanDisk Sansa e250 MP3 Player
My sansa express mp3 extremley slow
You may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Sep 16, 2008 | SanDisk Sansa MP3 Player
Only works sometimes
-Tha Mp3 Doctor
Jul 10, 2008 | SanDisk Sansa e250 MP3 Player
My Wheel Rolls EXTRA Slow!
Hey Kayla,
I had the same problem. What happened is i left mine in my car while i was working. This was not the first time either and when i got out of work in the late afternoon i noticed my sansa's wheel was incredibly hard to turn. I went home and searched for solutions and found your very same problem. I went downstairs and found that my dad had a pressurized can of Super Lubricant. 1 small, quick shot directly onto the wheel top and button got the spray lubricant on there good and i just wiped the excess lubricant into the wheel seams. Immediately start turning the wheel in either direction (try to switch back and forth) and it'll start to spin freely. The Heat of an enclosure like your purse or my car in the sun dries out lubricants just like the lube sansa applies in their factories to these products so just try this and tell me how it worked for ya if you still have it.
Sincerely,
Ben (belmont1@gmail.com) ( :
P.S. stop applying alcohol. That's more of a cleaner and all it will do is temporarily fix the glide sticking problem while simutaneously drying it out. Bad method...go with your every-day spray-lube.
May 04, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa E250 Black screen lighted wheel, wont do nothing else.
-Tha Mp3 Doctor
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Battery trouble
Just stop charging it and unplug it, then check on the top right of the screen to seen if it is fully charged.
Nov 25, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
