Asus M2N PS/2 port problem
Hi. I've purchased a custom computer with an Asus M2N and I can't get the motherboard to recognize any keyboard I plug in. Do i need to reinstall the drivers or enable PS/2? I don't jave a manual so I'm a little lost. Please help. Thanks.
    Problem Solver:
  • 7 Answers
There will be 4 no of fuses near the ps2 connector pls check them with mm for connectivity if all are ok then check the R pack near ps2 connector if both are ok then bga chif of mbd faulty & not repairable
Best solution is this use usb kbd & mouse
Posted on Nov 01, 2008
Hi, I am using ASUS M2N-MX SE Motherboard and I have purchase new Creative T6100 5.1 Speaker but only 2 Speaker working another are not working please suggest what can I do? Thanks and regards: Name:...
The rest of the speakers are recognized as being connected. How to fix that:
Unplug all speakers, open Realtek HD Control Panel utility (RTHDCPL.EXE) and start plugging them back. Everytime you will plug one a window will popup askin what was that you plugged in - tick the corresponding option.
May 27, 2010 | ASUS M2N-MX Motherboard
Ps/2 ports not working
Most likely the ports are blown. PS2 ports are very sensitive to static. Buy a USB to PS2 adapter and you will be back in business
Mar 14, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus logo comes up on boot but cant enter bios or anything else beccouse the keyboard doesn't work. I'we tryied other keyboards bbut they don't work to so i can't enter bios or install Windows my...
Most Asus motherboards by default have the USB ports enabled in the bios.
Buy the item, Y adapter below to bypass the PS/2 keyboard port on the motherboard; http://www.cablestogo.com/product.asp?cat_id=1538&sku=27225
You should be able to enter the bios using a USB port. Or buy a single PS/2 to USB; http://www.cablestogo.com/product.asp?cat_id=1538&sku=35700
Cheers'
Mike
Jan 20, 2010 | ASUS P4P800-E Deluxe Motherboard
On board USB ports not working
Right click the mouse on My computer located on desktop- select Manage- select device manager- find universal serial bus controllers - click on universal serial bus controllers - u find some devices there - right click the mouse on each and select uninstall - after uninstalling restarting the computer.
note : ensure usb controllers are enabled in BIOS setup for this , u should press delete key  at the startup of PC and locate it in Intergrated peripherals
Dec 20, 2008 | ASUS M2N-MX Motherboard
Onboard USB prrs malfuntion
Try re-installing the motherboard drivers. Here's a link:
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2V-MX-SE-Bios-0502.shtml
Hope this helps
Chris (ziraffa)
Asus M2N keyboard problem
You don't need a driver for a PS/2 keyboard nor a USB keyboard. The keyboard lights should lite up at post. After boot press the Caps Lock key and it will light the corresponding light on the keyboard if the controller works. If not it is the motherboard. If you are strapped for bucks get a mobo that can use the same cpu, RAM and drives. Good luck, Steve Medley
Nov 06, 2008 | Computers & Internet
Motherboard sound issues
Hi antlob,
Normally one would think something is wrong but if you look at page 2-23 in you're manual you'll see you're using the wrong plug-in (Lime green) (Rear). Plug you're spreaker jack into the
(Black sound out jack). See if that makes a differance?
To fine tune you're sound you can open Asus/RealTek sound effect manager listed in control manager. This program has connector sensing software & other goodies.
Enjoy!
Mike
Jul 20, 2008 | ASUS M2N-E SLi Motherboard
Usb Rumblepad 2 problems on a asus m2n-mx
Are the drivers for your device Vista compatible?
Head for the manufactuerer's website and get the latest software. There might be bug fixes that will solve your problem.
Apr 03, 2008 | ASUS M2N-MX Motherboard
Front Side USN dows not work in ASUS M2N MX SE
The front side port may be a "low power" USB port, it may be possible to "power" this if there is the capacity to connect a power cable to the front panel USB adapter, or there may be an aux power socket to plug into on the motherboard.
Nov 04, 2007 | ASUS M2N-MX Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
Computers & Internet Logo
469 people viewed this question
David Payne
David Payne
