Question about PNY XLR8 GeForce 8800GT 512MB PCI Express Graphic Card
Gateway FX7026 w/ 8800GT 512MB Video Card / Vista 64 Premium OS
When I turn on the machine, it runs fine (600/900/1500 MHz GPU/Mem/Shader). But after a short time (random - but less than 1 hr) it drops to 400/400/900), and performance drops to match. Even the screen saver looks choppy...sheesh.
This happens when playng WOW or just browsing the internet. Temps look OK (using GPU-Z to monitor), and fans are working.
Any suggestions? This has happened before, and went away. Seemed to come back with the latest Microsoft Updates, although that could be coincidence.
  • 24 Answers
It is a known issue. It is not a fault with the card, but a power saving method used by Nvidia. If the card is not being stressed, or even if it is, it will clock down to it's 2d speeds. This is fine if you are just surfing the web or other light tasks, but can cause chaos if you are gaming or folding at home.
You can force your card to run at it's maximum clocks in 3d mode by using a program called Riva Tuner. There are several good posts on the net on how to use this fix, but I can't seem to link to them as this site will not allow me??
I am using it myself, as I had the same issue with my 2 GTX 260's.
Posted on Dec 25, 2008
How do I find working XP video card drivers for a Gateway TA7/ Viper-SR laptop/tablet?
are you sure about the driver/chip? You may need to double check - was this an upgrade/ change of OS from a Vista machine? Or could it be direct x? read below.... otherwise I have no idea sorry ATI Mobility Radeon HD 2300 csm_ati_radeon_chip_05_e8206cf22f.jpgThe Mobility Radeon HD 2300 graphic card for laptops is the successor of the X1300 and supports only DirectX9 (according the informations of the AMD homepage). The performance shall be somewhat above the X1300 and therefore present average or worse game performance. AMD / ATI tells that the relation of performance/Watt has been improved. Rumours tell that the chip is only a renamed X1300 / X1350 video chip.
A difference to the X2300 are the amplified video options (UVD).
The HD 2300 graphic processor is certified for Windows Vista and supports the Windows Aero Glass Interface.
Manufacturer ATI Mobility Radeon HD 2000 Series Mobility Radeon HD 2300 4/2 cores @ 480 MHz 128 Bit @ 400 MHz Codename M71 Architecture RV5xx Pipelines 4 / 2 Pixel- / Vertexshader Core Speed * 480 MHz Memory Speed * 400 MHz Memory Bus Width 128 Bit Memory Type DDR1/DDR2/GDDR3 Shared Memory no
HyperMemory wird unterst?tzt DirectX DirectX 9c, Shader 3.0 Transistors 115 Million technology 90 nm Features 90nm manufacturing process, PCI Express X16 Interrace, PowerPlay 6.0, Avivo Video architecture (MPEG-2, MPEG-4, DivX, WMV9, VC-1 acceleration), 64-bit floating point HDR, Ultra-Threaded Shader Engine, OpenGL 2.0 Date of Announcement Link to Manufacturer Page http://ati.amd.com/products/MobilityRade...
Nov 25, 2014 | Gateway Ta7 E-295 Laptop Tablet, Core 2...
Assassins Creed iV Settings : Very Low But I cant run it good
Does your machine qualify for or above the minimum specification to run the game in all departments?
Minimum system required
CPU: Intel Core2Quad Q8400 @ 2.6 GHz or AMD Athlon II X4 620 @ 2.6 GHz CPU Speed: Info RAM: 2 GB OS: Windows Vista SP or Windows 7 SP1 or Windows 8 (both 32/64bit versions) Video Card: Nvidia Geforce GTX 260 or AMD Radeon HD 4870 (512MB VRAM with shader Model 4.0 or higher) Sound Card: Yes Free Disk Space: 30 GB
Jan 25, 2014 | Activision Spider-Man: Web of Shadows for...
The machine GPU doesn't support shader model 3, which is required to run this game
I install Burnout paradise the ultimate box and got an error when try to play the game...
this machine gpu does not support shader model3 which is required to run this game.
I have Intel(R) G33/G31 Express Chipset Family, Integrated Graphic
Intel Processor Dual CPU e2200 @2.2GHz
Memory 1.99GB
What can i do to play this game
Mar 03, 2011 | Computers & Internet
When i connect my graphics card to my pc i get a black screen there is no beeps and i cant even hear an windows sound. when i disconnect my gpu my pc works fine i have tried to disable onboard graphics...
Hello xvanpersiex, these are "Full Specifications" of your [Graghis Card].
"Check this to the 'Specs' of the "Motherboard to see if it 'Supports' the Graphic Card?"
"Try 'disconnecting, and reconnecting' the "Graphis Card"
Verify that 'all' the "Connections" are "Tightly Inserted."
*Go to the Control Panel > Device Manager > AGP Graphic Card > Verify Installed? >
Update Driver! > Restart Computer"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
ATI Radeon X1650Pro (AGP 8x, 512MB) General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Vista Capability This graphics card is capable of running the new Aero interface featured in Windows Vista Home Premium and higher.
  • Interface Type AGP 8x
Processor / Memory
  • Graphics Processor / Vendor ATI Radeon X1650 Pro
  • Graphics Card Performance This card's graphics processor and memory mean that it is not recommended for most games, but it will still be fine for office applications and other normal computing tasks.
  • RAMDAC Clock Speed 400.0 MHz
  • Video Memory Installed 512.0 MB
  • Technology DDR2 SDRAM 128-bit
  • Features Avivo Technology
Video Input
  • Type None
Video Output
  • API Supported OpenGL 2.0,
    DirectX 9.0
  • Max Monitors Supported 2.0
  • TV Interface HDTV out
  • Analog Video Format S-Video,
    Composite video
  • Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
  • Interfaces 1.0 x DVI-I (dual link) - 15 pin HD D-Sub (HD-15),
    1.0 x HDTV output - 29 pin combined DVI,
    1.0 x VGA
  • Compatible Slots 1.0 x AGP
Miscellaneous
  • Microsoft Certifications Certified for Windows Vista
Software / System Requirements
  • OS Required Microsoft Windows XP,
    Microsoft Windows XP Media Center Edition 2005,
    Microsoft Windows XP 64-bit Edition,
    Microsoft Windows Vista
  • Recommended Power Supply 350.0 Watt
  • Peripheral / Interface Devices CD-ROM
Feb 22, 2011 | ATI RADEON X1650 Graphic Card
I can't play pes 2010 because of gpu shader 2.0
Direct X 10 GPU with full Shader Model 4.0 support delivers unparalleled levels of graphics realism and film-quality effects.is what the manufacturers web site says
RECOMMENDED SYSTEM REQUIREMENTS:
[for the game]
* Windows XP SP3, Vista SP1
* Intel Core2 Duo 2.0GHz or equivalent processor
* 2GB RAM
* 8GB free hard disk space
* 8x DVD-ROM Drive
* DirectX 9.0c compatible video card. 256MB Pixel Shader 3.0 (NVIDIA GeForce 7900 or AMD/ATI Radeon HD2400 or better)
* DirectX 9.0c compatible sound card
* DirectX 9.0c or higher (included on Disc)
* Multiplayer: TCP/IP Broadband Internet connection
* Windows compatible USB Gamepad
* 1280 x 720 monitor resolution
where can i get a "GPU Shader 2.0?"
you need a new graphics card, shaders are a hardware limitation.
you can try to update the card http://www.pcpitstop.com/drivers/download/NVIDIA~GeForce~9500~GT.html i hope this helps you and please vote for me
Dec 02, 2010 | PNY TECHNOLOGIES NVIDIA GEFORCE 9500GT...
Problem for Acer Aspire M1641- PC Desktop
Hi I looked at your cards spec's its calling for a power supply of min 350 Watts,so I'd try replacing that.
here are your Spec's
GPU Clock MHz The main attributes of the GPU are the core clock rate, which typically ranges from 250 MHz to 1200 MHz in modern cards. 589 MHz Shader Clock (MHz) The number of pipelines (vertex and fragment shaders), which translate a 3D image characterized by vertices and lines into a 2D image formed by pixels. 1402 MHz Stream Processors Through the use of stream processing, computer benefit from the ability to transparently access a large number of 'cores' (or, computational units) on a chip without having to separately manage each and every one of them along with their associated busses, memories, I/O, etc. 16 Bus Type N/A PCI-E 2.0 Performance N/A Standard Memory Interface Bus (bit) The bit data rate between memory and the GPU. 64 Memory Type VRAM was typically based on DDR technology. During and after that year, manufacturers moved towards the vastly superior DDR2, GDDR3 and GDDR4. DDR2 Memory Size (MB) the video card will have its own video memory which is called Video RAM or VRAM. The VRAM capacity of most modern video cards range from 128 MB to 2.0 GB. 512 MB Memory Clock (MHz) The memory clock rate in modern cards are generally between 400 MHz and 2.4 GHz. 800 MHz Microsoft® DirectX® Support The standard for today's PCs and next-generation consoles enables stunning and complex effects for cinematic realism. NVIDIA GPUs offer the most complete implementation of the Shader Model feature set-including vertex texture fetch (VTF)-to ensure top-notch compatibility and performance for all DirectX applications. 10.1 Shader Model Support Enables stunning and complex special effects. Next-generation shader architecture delivers faster and smoother gameplay. 4.1 Open GL Optimization and Support Ensures top-notch compatibility and performance for OpenGL applications. 3.1 Minimum Power Requirement (Watt) This is the minimum power supply wattage requirement for the graphics card to perform properly. 350W Cooling Fansink Sometimes known as an active cooling device, a small electrical fan which drives air across a heat sink and as such will generate a small amount of noise. It is more effective than a heat sink alone at cooling. √ ROHS The RoHS Directive stands for "the restriction of the use of certain hazardous substances in electrical and electronic equipment". This Directive bans the placing on the EU market of new electrical and electronic equipment containing more than agreed levels of lead, cadmium, mercury, hexavalent chromium, polybrominated biphenyl (PBB) and polybrominated diphenyl ether (PBDE) flame retardants. √ Profile Some graphics cards have the capability to swap out the current bracket to make it compatible with low-profile computer systems that require a lower bracket card. Low PhysX Technology N/A √ CUDA Technology N/A √ Dimensions (Metric) N/A 16.8 X 6.93 X 1.9 Max Resolution Analog Maximum Screen Resolution indicates the maxiumum possible sharpness and clarity of an image that a monitor can display, measured in number of dots (pixels). 2048 X 1536 Max Resolution Digital Maximum Screen Resolution indicates the maxiumum possible sharpness and clarity of an image that a monitor can display, measured in number of dots (pixels). Hope this has helped and good luck,don't forget to rate...;-} 2560 X 1600
Jun 28, 2010 | Acer Aspire M1641-U1521A PC Desktop
I have a nvidia geforce 9400 Gt graphics card how can i overclock
Read this...
You're not going to get a lot out of that card, it's pretty stripped down being a 9400. Anyways, download Rivatuner then after it detects your video card it will update your registry which will allow it to manipulate your video card.
You then use it to increase your Memory and Core clocks, and also the shader clock in VERY small steps. Increase it by perhaps 20MHz then try playing the most visually demanding game that you own and play it for like 5 to 10 minutes and watch for anything out of the ordinary. When you've pushed your card too high there are obvious signs, like random pixels flashing across the screen, textures showing up wrong (colours where they shouldn't be), or your game can simply lag or crash.
Also download Speedfan and monitor your GPU temperature closely. See what it idles at normally, then use Rivatuner to increase your fan speed to somewheres around 75% and make sure that the temperatures don't pass 70C.
Overclocking voids warranties and you can damage your graphics card if you push it too hard. You have to be careful and watch for signs that it's being pushed too hard. Also, you have to make sure that you set your clock speeds back to normal when you don't need the extra power. It's easier on your card then running it at 120% or something permanently.
Rivertuner: http://www.guru3d.com/index.php?page=riv…
Speedfan: http://www.almico.com/speedfan.php
Hope it helps...Good luck
Jul 25, 2009 | Computers & Internet
My msi 4870 x2 2gb graphics card not shown 2gb only one gpu enabled what me do plz give me suggestion
first what OS using? win XP 32, XP 64, vista 32, vista 64.....would have to turn on within windows display properties
current drivers for R4870X2-T2D2G-OC
posible are using wrong driver for msi 4870 x2 OC version is for 2g RAM.
do you trust live update? on that page click here botton will run live up date and check if the msi hardware is up to date with firm/drivers
Jul 01, 2009 | ATI Computers & Internet
More ram and vdeo card
it sounds as if your MoBo is seeing the video adapter as a source of ram. if that is the case, then installing memory in units of 1Gb will cause a stick to not be seen, therefore utilized. you may want to refer to you manual for memory limits and poosible comparibility issues. they are usually quite in depth. also, make sure that they are all the same make model and speed. these issues have wreaked havoc on the prettiest of pc's.
Nov 28, 2008 | Computers & Internet
Video card with 64 mb and pixel shader version 1.1
Easiest way is to right click the desktop> click properties (or Personlise - in Vista)> then the settings tab (or Display Settings in Vista)>then advanced> then the adapter tab > you will then see a list of your graphic card,its memory and bios information.
Let me know what happens.
May 01, 2008 | Dell Inspiron 1501 Notebook
PNY XLR8 GeForce 8800GT 512MB PCI Express Graphic Card Logo
175 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
