Question about Maytag Kitchen Ranges
What is an F1 code on a maytag gas range - Maytag Kitchen Ranges
    Sergeant:
    Champion:
  • 324 Answers
Bad touchpad or control.to tell which one you can unplug stove and the unplug touchpad. then plug stove in.and see if error code returns. careful not to touch anything. if it returns then it is the control.
Posted on Nov 01, 2008
Door stayed shut and error code f1
You may have to replace the touch membrane or replace the electronic board behind the touch membrane. Also try removing power from the stone for fifteen minutes.See what happens.
F1 = failed electronic range control (erc)
Oct 24, 2013 | Maytag MGS5775B Gas Kitchen Range
Maytag double oven f1 code with buzzer
What is the complete model number of your unit?
Feb 10, 2013 | Maytag Gemini 30" Self-Cleaning...
Code F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 10, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
MAYTAG oven flashing f1 and f7?
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Keypad locked out
Consult your owners manuel for turning off the sabbath mode feature.
try to remember the whole f1 code. if it was f1-1 it could be a temperature problem
if it is f1-4 is could be a shorted keypad
the control pad could be locked out as well. try holding the cancel key for 3-5 sec to see if it unlocks the control
Feb 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
MAYTAG GAS RANGE MODEL # MGR5750 ADW
The range has sensed a runaway temperature. if you have a meter you can ohm out the temperature probe make sure it reads around 1270 ohms. if it is way off replace the temperature probe if it is close to 1270 replace the EOC. (Electronic Oven Control)
Dec 15, 2007 | Maytag MGR5751AD Gas Kitchen Range
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
136 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
