Question about Vehicle Parts & Accessories
Security car alarm
I have viper security car alarm it doesnt work anymore, when i shut off the engine the LED wil light solidly, then turn on the engine the LED is off and theres no sound when pressing arm button but the parking light flashing
On the 3 way pager press function 2 times then press unlock. that will get it out of valet mode
Posted on Feb 28, 2009
    Problem Solver:
  • 13 Answers
This sound like you have the system in Valet mode. You must locate the valet button usualy located inder the drivers dash or kick pannel. just turn key to on possition and hit button and then take key out. that should do it.
Posted on Dec 04, 2008
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I am trying to disarm the viper 5701 2 way alarm w/ remote start and the keypad nor is the manual override responding. How can I disable the alarm?
Get in car........alarm will be going offVisually find the black valet button..........it should be next to led on the antennaTurn key to IGN position...........so all dash lights are onWithin 5 seconds push the valet button 1 time..............may have been programmed to more times, but ussually notSiren should stop and you can start the car.
TO put into valet mode
Key to IGNKey to OFFPush valet button 1 time.Led should now be solid.
Jul 09, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm is on a 1996 f150 the alarm will not chirp the led on truck is solid it isnt blinking and it is a 5701 viper
Your alarm got put into valet mode some how
.It's easy to reverse out of it back to normal. First look for a small black push button under the dash somewhere. It's called a valet button. Here are the steps.
1. open door
2.turn key on then off
3.then within 10 seconds hit that valet button once(your alarm light should be off. Tell you arm it again. Then it will blink)
Hope this helps
Aug 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Have a 1995 tahoe disabled by viper security system. howdo i get the power baqck?
define disabled? if you mean it wont start, then turn the ignition on and press the valet switch untill the LED lights solid
Aug 13, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
I have a Viper 470v alarm and the keypad does everything it supposed to do as far as starting the truck locking and unlocking BUT it doesn't beep anymore and the screen doesn't reflect my status. It stays...
Is the red or blue light (LED)on the dash lit up solid? If it is then the alarm is in valet mode. 2 ways to take it out of valet. 1) open a door and press lock, unlock then lock again on your Viper remote. 2) turn the ignition on then off and press your valet/override button. The LED should go out and the beeps and status should come back. BTW you can also put the Viper into valet mode using the 2 methods above.
Feb 23, 2010 | Directed Electronics 479V Remote Gen 2...
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
1999 Toyota Corolla security system
Yes it does, there should be a black small button under the drivers dash .could be hidden so look with a light, once you find it you need to turn your ignition on then turn it off and press the button within 10 seconds the LED should turn off and the alarm should be working normally
Sep 23, 2008 | 1999 Toyota Corolla
Vehicle Parts & Accessories Logo
366 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
