Question about Compaq Evo N600c Notebook
N600c's bios can't support 48-bit lba?
I change n600c's harddisk with wd scorpio blue 250GB,but only 131GB can be recognized.I used intel 48-bit lba test program to find n600c can't support large disk more than 137GB.I contact hp technical support but they did not seem to care.
  • ichtys7 Mar 14, 2009
    Hello qqdtst!
    I also was about to upgrade to a new HDD WD Scorpio!
    Did you try to make two partitions about 125 GB each? Maybe the BIOS will recognize your new HDD (250 GB) in parts?
    Try that!
    Greetings from Sweden and Carl
  • David Shaub May 11, 2010
    You can only use what your computer will recognize. Even though it will fit physically, bigger isn't always better.
It depends what you want to use the laptop for but Windows XP SP2 (Disk needs Service Pack integrated), Windows Fundamentals for Legacy PC's and Windows Vista and Windows 7 will correctly address a hard drive within a machine that has the 137gb 48bit LBA problem.
Posted on Sep 04, 2009
Compaq evo n600c start up has an email in it ask for a password but wont let me type it in and f10 thers an error
Entering and Exiting the BIOS Power on the system. Press F10 when the blinking cursor appears in the upper-right portion of the screen. Select a task from the following menus: File, Security, or Advanced.
To exit the Bios, select the File menu. Choose either Ignore changes and exit or Save changes and exit, and then press Enter. When you are prompted to confirm your choice, press F10
Feb 01, 2014 | Internet Compaq Evo N600C Laptop
We cloned an older 58GB drive to a WD2500BEVT 250GB drive (using Acronis True Image 2011). The WD 250GB drive is now reporting as 58GB to BIOS. I've 0-filled it with different utilities. no...
Good day!!..As far us i know that cloning or ghosting should be the same specs of hard disk..Since you want to cloned the 58gb,so you should be use 58gb also and not 250 gb,thats why bios detecting some different utilities..ok thanks..
Aug 19, 2011 | Western Digital WD Scorpio Blue WD2500BEVT...
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
Adjust screen brightness evo N600c
using the blue Fn key(usually on bottom left to side of space bar)..look at Funtion keys on top, under the screen. One of them(F5 or F8) will have a blue sun image or a monitor image to increase or decrease the brightness. press the Fn key first, then the one that increases brightness until it's good .
Nov 28, 2009 | HP Compaq Evo n600c Notebook
Lenovo 3000 N200 Not recognize my WD Scorpio 160Gb HDD sata
When a hard drive is not recognized in the BIOS then it indicates a hardware malfunctioning. In this case, service is required.
Sep 15, 2009 | Lenovo 3000 N200 Intel Pentium Dual Core...
Installed a 250GB WD Scorpio and it shows as a 130GB drive
make sure the laptop will handle a drive bigger than 130 gig. if not make two partitions when you set it up, bios wont see it but usually windows will. also, sometimes ive found that if i delete the partition a few times it eventually reads right. dont know why but have done it that way several times. you can also download a diskmanager program from thier website which makes an overlay if your bios wont support a 250.
Aug 23, 2009 | Western Digital Caviar WD2500BB 250 GB...
Upgrading hdd in hp ze4805us to 250GB WD -- Won't Boot
since your bios says theirs a limit to HDD capacity you may want to try making the 250GB disk into 2 smaller partitions. Then extract your OS image to the first partition.
Apr 16, 2009 | HP Pavilion Ze4805us Notebook
Windows does not see full size of new Hard drive
Is your disk correctly partitioned?
  1. Right-click My Computer.
  2. Click Manage.
  3. Click Disk Management.
Find your newly installed disk and see if there is any unpartitioned space on it. If there is, just create a new partition, or delete the previous one so you can create the partition which will consume full size of the disk.
Jan 15, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Compaq Evo N600c Notebook Logo
412 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
