Question about LaCie Computers & Internet
My LACIE 500gb drive appears dead - I cannot get it to activate. I have not used it for a month. I attempted tp power it up this morning - no power.
  • 1 more comment
  • nevillazarus Nov 01, 2008
    I cannot feel or hear the drive spinning
    All connections and wiring are good - still no power - no spinning
    Where is the service centre?
    Brigadier General:
  • 3,614 Answers
Try to check all wire and cable connection. it could be only on the connection or into the wire you have the problem.
Posted on Nov 01, 2008
  • micromaster
    micromaster Nov 01, 2008
    change the wire and try testing it into another input.
    also for clarification:
    • is the drive was connected internal or external?
    • did you got a power coming on your pc.?
    thanks
    Genius:
  • 1,847 Answers
Can you feel the drive spinning?
  • Legin Varghese
    Legin Varghese Nov 01, 2008
    check if is recognized by the computer, got to the device manager and check there.
    If you don't hear if spin that mean the it is dead, you cannot repair it yourself, you have to send it to the service center.
  • Legin Varghese
    by service center i meant the LaCie Technical Support
    https://www.lacie.com/mystuff/login.htm?...
    Thanks
    Kevin
LaCie 500GB portable hard drive is giving error 43. It was working fine for a few weeks and now I can't get into it from either of my computers. I tried uninstalling the USB Controllers but still same...
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If a different LaCie product is available, borrow the power cabling from that unit to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to a second port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test.
Then run
Dec 22, 2010 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Hi, I have a LaCie 500gb external hard drive that appears to have locked up. Cannot connect and can hear a clicking noise. please help
It's probably the power supply.
Do you have a friend with a similar model who can lend you his/hers to test? Otherwise ebay...
Sep 25, 2010 | LaCie (300770) 250 GB Hard Drive
Lacie do not start
If it still is under warranty, then exercise the warranty, and get it repaired/replaced.
If it's out-of-warranty, then disassemble the case, and disconnect the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk-drive still works.
If it's dead, it's dead, unless you pay mega-dollars to a professional "Data Recovery Service" to rescue your files.
If it is dead, then buy another disk-drive that is compatible with that USB-to-disk-drive adapter, and reassemble the unit, and you'll have a brand-new external drive that you can use.
May 29, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
When plugged in, icon doesn't appear on the desktop.
We have a few of these Lacie Design by F.A. Porsche 500GB drives in our office. Our editor's drive stop working this morning (was fine the day before) and had all her files backed up from the last three years on it and was making a very soft clicking sound. After taking the whole thing apart and trying drive in another F.A. Porsche caddy with no success, we tried a different power supply hey presto it started up no problems. My drive that suddenly stop working earlier in the year we tried a power supply from a external Lacie DVD Writer and again drive is working. Just to make sure tried the original power supply and would not mount. So if your hard drive stops working it maybe the power supply rather the the hard drive.
Jun 25, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Hard appears to be dead
Microsoft has several methods to fix USB devices not recognized by PC. Click on the link below and scroll down to the Resolution section. Hope it all works out for you.
Greg
http://support.microsoft.com/kb/871233
Jun 06, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie drive makes popping noise, goes offline, corrupts files
I'm afraid your hard drive is cactus. The popping noise is most likely the read head hitting the cylinder. This is causing more and more physical damage to the PC as it attempts to read the files. You will most likely need to consult the supplier of the equipment for a warranty replacement, or go through the vendor. If the drive is out of warranty I suggest buying a new one and throwing the old away.
There is no way to recover a drive that is physically colliding the head with one of the drive plattes.
Apr 15, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
55 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
