Question about Bernina Virtuosa 160
Feed dogs are not coming up high enough to catch the fabric
The feed dogs are not coming up high enough to catch the fabric when I first start feeding in the fabric. I just had the machine serviced and cleaned and I expressed this problem and he said everything is fine. But I know this has not been addressed. It is still not working properly. I need to put the fabric in under the needle at least 2 stitches past the needle for it to start pulling the fabric through.
sandischaab@gmail.com
  • sandis Nov 09, 2008
    Thanks to Bob I'm up and running again. Sandi
I have had similar problem with my virtuosa 155. If you can't get it into the shop to have feed dogs adjusted - try starting a small scrap of fabric first , then chain sew with your piece right behind it. This has worked for me. Also if you finish with a scrap as well, it saves thread as you don't have to pull so much extra into thread cutter. Just snip between pieces.
Posted on Dec 19, 2008
As your tech i have fixed your feed dog height ablevac and sew cleveland ohio
Posted on Nov 07, 2008
    Problem Solver:
  • 13 Answers
The fault is with the height of the feed dogs it is an internal adjustment that you tech. should make. As a guide if you cant see the majority of the front teeth above the plate or feel them with your finger then they are to low and need to be raised. Also check that the pressure of the sewing foot is set in the right position on the left side of the machine.
Posted on Nov 02, 2008
I have a singer sewing machine and my feed dogs won't advance my fabric?
Make sure the stitch length is set high enough to actually move the fabric, ie #2 or higher. Are the feed dogs in the raised position or have they been dropped for darning?
If it's an older mechanical machine, it may need a very thorough cleaning and Oiling. Old oil will cause the machine parts to seize.
Apr 23, 2017 | Singer Sewing Machines
Janine Jem platinum 760, ,needle just going up and down, have cleaned and checked feed dogs are up and moving help what's wrong, are the dogs too low is there a adjuster can't find it ?
Make sure the stitch length is set high enough to actually advance the fabric--the feed dogs actually need to move forward and backward.. The stitch length control controls how much the feed dogs move the fabric. Also, check if your machine has a presser foot pressure control. This manages the amount of pressure the presser foot applies to the fabric, causing the feed dogs to grip the fabric in their movement.
If these do not resolve the issue, you may need to take it for service.
Mar 10, 2017 | Platinum Sewing Machines
How do I get the feed to work? The cloth isn't moving through the machine.?
Check that the Stitch Length is set high enough to actually advance the fabric, ie #2. Also, have the feed dogs been dropped, ie for darning? Be sure the feed dogs and bobbin area are cleaned of any lint, thread pieces, and gunk. If it is an older machine, perhaps the feed dog tips are worn. Is there enough pressure from the presser foot to actually force the fabric to react to the feed dog movement? Otherwise, the machine may require service.
Feb 19, 2017 | Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
My feed dogs are raised but the machine will not feed the fabric fast enough even set at 5
Obvious things first:
is the pressure foot lowered to hold the fabric down?
Are the feed dogs clean and not blocked up with lint?
What stitch length have you set the machine to (if this is what you mean by "5" then that's not it obviously)
Is the machine in a buttonholing sequence or something similar?
Are the feed dogs moving at all in the stitching sequence? Raise the pressure foot and without fabric or thread manually turn the flywheel towards you and watch them moving. Are they coming up above the surface of the needle plate during their sequence.
If they are not moving at all, good chance a gear in the lower shaft has failed.
If they are moving but not coming up above the needle plate enough to move the fabric backwards, then they need adjusting to the correct level.
Sep 03, 2011 | Sewing Machines
My machine has been in the basement for a while. Now my feed dog does not rise up high enough on my bernina patchwork 140 to catch the fabric. I did take the plate off and it is clean. Any suggestions?...
It seems strange that the feed dogs would change position while in storage. Are they moving at all?
They haven't been disenaged and lowered somehow, most machines have a switch or slide somewhere that disengages the feed dogs for freehand embroidery etc.
Jun 08, 2011 | Bernina Activa 140
Yes we know . bit they are down they dont seem to be high enough up .not pulling fabric through .
Remove the needle plate and check for lint build up between the feed dog teeth. Lint will build up and prevent the feed dogs from coming up all the way. I them still don't come up high enough, then they will have to be adjusted.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
Kenmore model 158 15510 will not catch the material to advance it while sewing. The catch plate does not go up high enough.
Feed dogs.
Check the manual for how to engage/raise the feed dogs.
Or, it could be the machine needs cleaning.
Open the bobbin area and the throat plate (plate under the presser foot) and clean with a soft brush or cotton swab.
Apr 25, 2010 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
636 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
