Question about Dell Dimension E521 PC Desktop
Installing memory eveeytime I try I get a blue screen
  • Chris Busch
    Chris Busch May 11, 2010
    This could be because its not compatible or because the memory slot is bad, or its in the wrong position.
    I need some details please.
    is this a P.C. or laptop ?
    If a P.C., how many memory slots available, what is the size of the memroy sticks, what is the speed or specs of the memroy sticks?
    should say on the memory.
    Also, are the memory slots alternating colors like two are black and two are blue?
    let me know, thanks.
  • Dell Master
  • 3,051 Answers
HI THERE
if you boot into bios as the computer starts the memory amount will show up and it will say system memory updated once you are in bios and you are on the first page just look down the lines and you will see the memory and the slots they are in you will get a erroir message if there is a memory problem and the beeps will be present 3.3.3
Posted on Feb 18, 2009
When i try to install windows xp, then all files are extracting rightly but when start up is loading suddenly blue screen appers. so plz help me to solve this problem. give me suggestion.
Hi jenishrabadi, Have you tried using different source software for your windows xp installation.
There should be an error code when you receive the blue screen. post the code here, it may seem like 1) either corrupt software or 2 ) Faulty hardware. Most likely memory.
without further performing any more diagnostics (as we do not know what the actual error is) and making the assumption it is faulty hardware, if you have more then one memory cards in your notebook, try and take one memory card, then try the setup/install. if this fails .. put the memory card back in, and remove the 2nd memory card and try again.
good luck ... hope this helps ...
Oct 07, 2010 | Compaq Presario Notebook
I installed additional memory to my TOSHIBA laptop, and after this process it started rebooting itself, a blue screen Windows kept showing up, and when I tried to fix with a Toshibas's software, the...
Yes I would have thought so. The blue screen is most likely caused by some memory. If it was working ok before installing the new memory, then it is either the new memory, or a faulty memory slot on the motherboard
Jun 08, 2010 | Toshiba Computers & Internet
Blue screen error acer desk top
hi friend the blue screen comes when there is a 1:hardware problem
2:virus problem
3:Installation Disk is corrupted
4:RAM problem
First, check your CD and clean or replace it as necessary. Your next step should be to test your system memory for errors with a diagnostic program.
To do this obtain the Windows Memory Diagnostic or Memtest memory diagnostic programs on floppy or CD we mentioned earlier, and use it to boot your system and test the memory. If either of these programs shows any errors in your memory, you have likely found the source of your troubles.
Chances are you will need to purchase new memory. For more information on faulty memory and memory diagnostics, see PCstats Guide to diagnosing bad memory .
Mar 31, 2010 | Acer Aspire™ T180 PC Desktop
Blue screen all the time, even after clean install??
Check your memory modules....the blue screen of death happens more frequently when associated with either bad memory or unseated module. Try removing a module and changing them around to see if the machine boots.
Nov 24, 2009 | Systemax Pursuit 2130 Notebook
ThinkPad Blue Screen of Death
Sometimes the blue screen can be caused by bad memory, but if it is doing it right when you try to sign in every time, it is probably a software corruption in windows. I have solved this problem by doing a repair install of windows xp, I am not sure if is an option on other os, if you google it you will find directions, you boot off the windows install disk and this option saves your programs and data.
Oct 27, 2009 | IBM ThinkPad T22 2647 Notebook
Blue screen error
check the ram memory ...and after remove and put it back in ...with care ...remove the bios battery to restore optimal defaults ...also try to format ntfs quick ..cause if the hard drive has some issues it will block during the normal installing ..but ussualy those 00000000 on blue screen are from ram memory issues...
Sep 09, 2009 | Acer Aspire 4530-5889 Notebook PC
A blue screen came up saying something about the memory module!
oh k..
so u mean whenever u start ur computer or whenever u work on it, it shows Blue screen...
This blue screen is called BSOD Error (Blue Screen Of Death)
It occurs due to several reasons but since u specified abt memory, this might be showing you Kernal Memory Dump, i hope..
Dont need to panic, try to start up computer in safe mode & restore it to previous known date at which u didn't had that problem..
It generally occurs after installing some new softwares or drivers that conflicts with the memory module.. so try to restore ur system else try removing ur newly installed software or driver...
Hope this helped u out..
Thanks....
Aug 27, 2009 | Toshiba Satellite A65-S1062 Notebook
I cannot install OS winxp onto sata drive pc is Acer aspire x3200
There could be two reasons for the blue screen either a bad harddrive or loose memory cards in the slots. Try reseating the memory cards on the motherboard.
Also please post back the Stop code you are getting on the blue screen
Thanks for using Fixya
proton
Jul 27, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
Sir every time I open my PC there's a blue screen appearing then it shuts down but sometimes when I log in it's OK and if I open any program the blue screen appears again then will shut down. What would I...
Hello my friend, regarding your problem do you have installed program or driver software lately before this blue screen appear? i guess the problem here is more on the memory dumping of your computer. either the latest installed software is not functioning will or  u have a memory device problem either to much heat or cause by some circuit problem that made the memory device problematic. the worst case here is to replace memory but for now try to check first if the memory is running well and stay in its standard cooling temperature. Or you can reprogram your computer.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computer crashed
that is a memory dump, try to remember what hardware or software did you install or uninstalled recently, if you can log-in on windows try uninstalling or reinstalling the hardware or the software. if it fails, run the windows recovery on the cd and repair the windows installation.
Feb 18, 2008 | Dell Inspiron 6000 Notebook
Dell Dimension E521 PC Desktop Logo
83 people viewed this question
Alun Cox
