Question about ECM Giotto Espresso Machine
When I pull the lever to make an espresso it takes about 10 seconds for water to come out. It's as though all the water in the boiler (or heat exchanger?) drains out when I dont use the machine for about 20 minutes. I have noticed that it drips a bit out of the bottom of the group head. Maybe there is a leak in the discharge valve causing the water to leak out? I really am not sure what is going on with it.
    Problem Solver:
  • 9 Answers
Tank fills automatically with level electrode on top of boiler. Same punp that brews your coffee will top up the tank. Electrode full of scale - no water in tank. The boppom of group has drain exit. Fully normal to have a bit water to drain out. tale apart and clean manually! Nothing to be afraid of. take photos as it can get tricky to get all pcs back after mayor overhaul. Larger commercial machines have the drain outlet covered behind a vertical wall. You don't see the water but the E61 group is identical!! ///Olev
Posted on Mar 21, 2009
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
I have an incanto sirius espresso maker and cannot get the screen to come on. As soon as I plug it in the boiler overheats (too hot to touch within 10 seconds. Could this be the overall failure I am h
Sounds as though there is no water reaching the boiler. Does the pump run when the machine is first turned on? Is there a water filter in the feed line from the water tank that may be blocked?
If the pump is not running at all, it would pay to check if there is voltage reaching the pump motor (BE CAREFUL! Only do this if you know exactly what you're doing)
If the pump is running OK, the water filter is not blocked and all the hoses are in their correct positions and not kinked or detached, then the only really likely thing left is that the boiler is blocked with scale, stopping water from entering the chamber
Nov 07, 2013 | Saeco 00034 Incanto Sirius Super Automatic...
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
It's that danged power outage. Creates havoc every time and I can't always figure out how I get it to heat back up. Unplugging, plugging in, starting with the steam valve open for no less than 10...
Hi Any time you turn on your machine, always open the steam knob and make sure that you have a full boiler by having water come out of the wand when you turn on the pump switch. Until you have water coming out your boiler is not full. If its not full maybe the heating element has nothing to heat. This is how heating elements get damaged. They will heat until they blow, then you will never have heat. Make sure that you have water in the boiler, please. If it still doesn't heat, your thermostat may have tripped or your thermal fuse might have blown, or your board is shot. Now if your talking about the GFCI in the wall, there is a reset button on the GFCI that controls the outlet your machine is plugged into, or should be. Make sure that you have power to your outlet.
Jun 11, 2011 | FrancisFrancis! X1 - Stainless Steel...
Water not heating. Red light stays on.
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won't heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Apr 07, 2011 | Rancilio Silvia Espresso Machine
Water doesn't heat up
Jan 22, 2011 | Rancilio Silvia Espresso Machine
Rancilio Silvia indicator light not turning off
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Saeco royal professional excesive hot water and steam though capp
HI
These machines run water through the boilers and is heated to either 192 degrees for the main boiler or 250 degrees for the steam boiler. There is mineral in all water except distilled. That mineral deposits itself inside you boilers and needs to be removed. I guessing that the water hardness in your menu is set on 1, but should be set on 4. You need to descale more often than not enough or you get what is happening to you right now. I am hoping that a good descaling will do the trick, but it might take 2, that it needs. Use a commercial descaler for espresso machines, not vinegar which will leave a taste for about 2 weeks.
Oct 25, 2009 | Saeco Royal Professional Espresso Machine
Switch or Fuse?
Probably the thermal reset on top of the boiler.
Mar 26, 2009 | Gaggia Achille lever operated espresso...
Heat temp and time
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
ECM Giotto Espresso Machine Logo
144 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
